_mproserv.exe
At 12:22 PM 3/29/2001 , you wrote:
>My Vantage installation is running on a memory starved server with dual
>processors. I have ordered and upgrade to 1Gig. In the meanwhile I would
Good call! If anyone hasn't noticed... RAM is at an all time low price
right now. You can get 256MB of server memory for around $150. I bought
256 for my new home PC for only $79 :) www.crucial.com has great quality
memory for just about everything.
>When checking the processes I noticed about twenty instances of
>_mproserv.exe were taking up about 4Mb each. Is this normal?
For how many clients? Are you using the work around for the Progress
problem that plagued 4.0 last year? That modified some Progress parameters
so there was one server process per client connection. Below is a blurb I
saved from Epicor. There was also an -Ma (??) parameter that needed to be
set, but I don't see it mentioned.
[[From Epicor tech suppt]]
>If you are a Vantage 4.0 customer that was using the (-Mn) parameter
>workaround solution, Vantage Technical Support would recommend that
>you adjust the (-Mn) Maximum Number of Severs parameter value after
>loading the Progress 9.0B29 patch. Starting a server for each client
>connection is fine except that it uses more server resources than is
>necessary to support a single client connection. As a rule of thumb,
>a single server process can handle 5-10 users. A reasonable (-Mn)
>Maximum Number of Servers parameter value can be determined by
>dividing the (-n) Number of Users parameter value by 5. This new
>value will result in the same client performance but with a more
>efficient use of server resources.
-Wayne Cox
Hello all,
like to keep things running as good as possible. When checking the
processes I noticed about twenty instances of _mproserv.exe were taking up
Thanks!
Paul
