1 purchased part multi stocked parts?
Gary is correct: APM provides the capability of producing multiple end parts on a single job. However, it is a function very much designed to combine existing jobs (sharing very similar methods) opportunistically by planner schedulers (in order to save multiple repeated - otherwise single shareable - set ups).
In your case, you would have to set up Parts 1,2,3 & 4 as fabricated parts (all with common OP details - each representing 1/4 of the true disassy cycle time) with BOMs requiring .25 per of Purchased Part A.
Create/schedule equivalent qty Jobs for Parts 1,2,3 &4. Then immediately combine the Jobs into one (before releasing and traveler printing).
You can not unfortunately, set this up permanently via a single Part master rev MoM record. You can set it up as 5 records (Parts, 1,2,3,4 & A) and then 'remember' that 1,2,3,4 are to be combined into a single job.
I never tried it, but (assuming the system may allow it) a better alternative might be to create a precombined job (for parts 1,2,3 & 4) and then save it as a Template Job for repetitive use.
Rob Brown
Gary Parfrey <garyp@...> wrote:
Norman
The advanced production module has' job parts' which deals with this.
Gary
Dot Net IT Limited, Reg No 4412519
Of Norman Hutchins
Sent: 31 January 2008 23:13
Subject: [Vantage] 1 purchased part multi stocked parts?
I have an interesting issue that I was wondering if anyone has dealt
with or
if anyone has any ideas.
We have some parts that we buy from a supplier with one part number and
when it comes in house we take it apart and now it multiply part numbers
in
stock. I need to come up with a way of dealing with these parts. Right
now
it is a manual process; the parts come in, a job get made to have it
taken
apart, than manual quantity and cost adjustments get made so that now
the
one part has become multiples.
Basically like this:
1 part A is purchased from the supplier, than disassembled
Now we have 1 of each of parts: 1, 2, 3 and 4 and no part A
Any ideas???
Norman Hutchins
Network Administrator
Howell Laboratories, Inc.
Never miss a thing. Make Yahoo your homepage.
I have an interesting issue that I was wondering if anyone has dealt with or
when it comes in house we take it apart and now it multiply part numbers in
stock. I need to come up with a way of dealing with these parts. Right now
it is a manual process; the parts come in, a job get made to have it taken
apart, than manual quantity and cost adjustments get made so that now the
Any ideas???
Norman Hutchins
Norman
Gary
Of Norman Hutchins
with or
in
now
taken
the
Any ideas???
Norman Hutchins
