10.0 BOL Pack Linking Issue
Hello,
On Epicor 10.0 we are having an issue where it seems that when I link a Master Pack, not only the Master Pack of that pack number but also a Pack of that number have the BOL and BOL line fields populated with that BOL num. This is causing some issues as we have a BPM that pulls some info over so incorrect data is being pulled over from Packs that have the same pack number has Master Packs that are being linked to the BOL. This seems to be a bug? as only the Master Pack should have its BOL field populated with the BOL number its being linked to however both the Master Pack and Customer Shipment Pack with the same pack number are having the pack record populated with the BOL number in their BOL num fields. Has any seen this before? is there a hot fix or patch for this? any info is appreciated thanks.
