Got it. Dang *All Files* was blocking it. Thanks Rob.
Sent: Monday, February 15, 2016 5:50 PM
Subject: RE: [Vantage] 10.700.4 MES Customization Deployment
Look for Erp.Menu.Mes.dll
Rob Bucek
Production Control Manager
D&S Manufacturing
301 E. Main St. | PO Box 279
Black River Falls, WI 54615
715-284-5376 Ext. 311
Mobile: 715-896-3119
rbucek@...
Visit our newly redesigned Website at
www.dsmfg.com<http://www.dsmfg.com/>
Sent: Monday, February 15, 2016 5:05 PM
Subject: [Vantage] 10.700.4 MES Customization Deployment
I am trying to deploy a customization I did for MES. I found the directions below from a couple years back but in #3 "Epicor.Mfg.Menu.Mes.DLL" is not available in the program search.
Deployment consists of creating a subprocess menu Id, a Process Calling record, and modifying the default mfg.sys file. Here are the steps:
1) Go to System Maintenance --> Utilities --> Menu Maintenance
2) In the Tree View highlight PROCESSES .
3) Select File --> New --> New Menu
- Menu ID must be unique and start with "UD"
- Enter a Description. This will be seen by the user from the Menu
- Select a security group that fits the people that will be using MES.
- Provide an order sequence number which positions MES in the menu.
- Now select "Non Menu Item" from the Program Type dropdown.
- Select "Epicor.Mfg.Menu.Mes.DLL from the Program Search.
3) Select your customization from the Customization dropdown.
4) Save the new Sub Process Menu.
5) Go to System Maintenance --> Utilities --> Process Calling Maintenance
6) Select File --> New
- Called Process Reference is "Epicor.Mfg.Menu.Mes".
- Leave Call From blank.
- Menu Id is the unique Id that you gave to menu in step 2.
7) Save the new Process Calling record.
8) Logout of Epicor 9.
9) Run ConfigEditor.exe which is in your Epicor client folder.
- Select the configuration file that is used by MES.
- On the Application sheet scroll down until you find MESCustomMenuID.
- Enter the unique ID that you gave to the Menu in step2.
- Click Save and then close the application.
HINT: Step 9 must be repeated for each client that runs MES and for the server client.
Mark Tellefson | Information Technology | www.rapat.com
Phone: (218) 483-3344 | Toll Free: (800) 325-6377
Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient and received this in error, please contact the sender by reply e-mail. You are hereby notified that the copying, use or distribution of any information or materials transmitted in or with this message is strictly prohibited.
