2023.1 External Datasouce
Anyone using external datasource in 2023.1?
Just did an upgrade and all of the setting were removed. I cannot re-add them as well.
User is in the database. Same settings as 10.2.600,…
What could I be missing?
Prod Settings which work.
you have SSPI on on the second screen, you name/pwd usually is ignored in that case, AFAIR. You are probably logged in as App Server pool identity
which means it was misleading all along.
ok. let me try that out.
thanks!!
