I’ve encountered a bug after upgrading Kinetics. The production environment is currently on version 2023.2.9, and I’ve installed version 2024.2.6 in another environment.
While running my code—which worked in the previous version—the GetReportBytes function now always returns an empty byte array. I haven’t been able to determine the cause yet.
Here is the code I’m working with (located in Data.SysTask.Standard):
var ttUpdated = ttSysTask.Where(r =>
r.TaskDescription == "BAQ Report-GN_JobTravCS_2 (GN_JobTravCS)" &&
r.TaskStatus == "COMPLETE"
foreach (var ttSysTaskRow in ttUpdated)
if (ttSysTaskRow == null || string.IsNullOrEmpty(ttSysTaskRow.Company) || ttSysTaskRow.SysTaskNum == null)
continue;
int i = 0;
while (!Db.SysRptLst.Any(row => row.Company == ttSysTaskRow.Company && row.SysTaskNum == ttSysTaskRow.SysTaskNum))
System.Threading.Thread.Sleep(50);
if (i > 25)
return;
i++;
var SysRptLstRow = Db.SysRptLst.FirstOrDefault(row =>
if (SysRptLstRow == null || SysRptLstRow.SysRowID == null)
continue;
var Character01Row = Db.SysTaskParam.FirstOrDefault(row =>
row.SysTaskNum == ttSysTaskRow.SysTaskNum && row.ParamName == "Character01"
System.Threading.Thread.Sleep(10000);
var hMonitor = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.ReportMonitorSvcContract>(Db);
byte[] bytes = hMonitor.GetReportBytes(SysRptLstRow.SysRowID);
DocumentType documentType = DocumentTypeDeterminer.DetermineType(SysRptLstRow.SSRSRenderFormat);
string str = FileExtensionDeterminer.DetermineFileExtension(documentType, bytes);
string str1 = string.Empty;
if (Character01Row != null && !string.IsNullOrEmpty(Character01Row.ParamCharacter))
str1 = Character01Row.ParamCharacter;
else if (!string.IsNullOrEmpty(ttSysTaskRow.TaskNote))
str1 = serverPath + ttSysTaskRow.TaskNote;
else
str1 = serverPath + DateTime.Now.ToString("yyyyMMddhhmm_")+Session.UserID;
var tempPath = Path.GetDirectoryName(str1);
if (string.IsNullOrEmpty(tempPath))
continue;
if (!Directory.Exists(tempPath))
Directory.CreateDirectory(tempPath);
if (bytes == null) throw new BLException("Bytes for PDF is empty.");
File.WriteAllBytes(str1, bytes);
I’m wondering if anyone else has encountered this issue and could share their solution.
Alternatively, if you have a different approach to saving the file generated by SSRS, I’d greatly appreciate your input.
We are using this method to perform PDF management tasks with PDFSharp afterward. This includes operations like rotating specific pages within the file and scaling the drawings to perfectly fit the sheet size.
Regarding the file system changes, I am aware of them, but I still hope there will be a way to handle file management programmatically moving forward.
That would be the next step, as the UserID is currently only used for the folder path. I think you’re right—it now seems to be the user from the task agent.
I added the Security Manager role for the Task Agent User, and it’s now working. However, I don’t believe this is the ideal solution. Do you think the issue could be related to the territory rights?
The report is now working by accessing it directly through the DB object.
The issue occurred because placing the BPM on this table caused it to trigger multiple times. By waiting for the task to complete, the data should have been generated. However, for reasons I don’t fully understand yet, it wasn’t working as expected in some cases.
If I recall correctly, the SysRptLst table triggers the update statement multiple times. It’s been over 5 years since I implemented this BPM, so my memory might be a bit fuzzy.
