Title basically explains what we have started to encounter after upgrading to 2026.1 In previous versions when entering a PO line that contains a subcontract job, the operation would be selectable from a dropdown now we no longer receive the dropdown so the user must know the correct operation and manually type it in, has anyone else encountered this problem or know of a workaround? I attached a couple screenshots from the user who initially encountered the problem for reference.
Ours are still drop-downs in 2026.100.9 (Live) and 2026.104.0 (Pilot).
Can you verify in App Studio if your column is still set to be a combo?
Same version as yours 2026.100.9. No dropdown in grid. Ended up modifying the column to replicate the same combo behavior as in the detail form.
I just did the same and the functionality returned, odd that they removed it from the base form in this upgrade. Thanks for the point in the right direction David.
