2D barcodes Blank Title 91510
Something sounds familiar here.
I have a feeling when we moved from 8 to 9 we had an issue where the barcodes on
MES didn't quite work.
The below info 'might' help ...
Â
Try setting the AutoEdit property to false (if not available in
designer propeties, it will have to be done in code)
here is a description of the property:
public bool AutoEdit { set; get; }
Member of Infragistics. Win.UltraWinGrid .UltraCombo
Summary:
Determines if the combo will support automatic value completion.
(Default is true).
Remarks:
Setting the AutoEdit property to True will enable automatic edit
value completion for the text area of the combo, based on the values
in the value list. When AutoEdit is True and the user types a
character in the combo's text box, the control will search the
contents of the
Infragistics. Win.UltraWinGrid .UltraDropDownBa se.DisplayMember column
to see if it contains a value that begins with the same character. If
it does, this value will appear in the text box, with all of its
characters highlighted except the one that the user typed. If the
user types a second character, the control will check to see if it is
the next highlighted character is in the value that appeared. If it
is, the value stays and the character typed becomes deselected. If
the second character does not appear in the value, the control
searches the list again for a value that begins with the first two
characters that were typed. If one exists, it appears in the text
box; otherwise the selected text is removed and no more searching
takes place. This process continues until the user shifts the input
focus away from the control. If the UltraCombo's
Infragistics. Win.UltraWinGrid .UltraCombo. DropDownStyle has been set
to DropDownList, then setting the AutoEdit to true will enable multi-
character auto-edit functionality for the drop down list style. In
multi-character auto-edit mode, the control will select the item
whose text starts with characters typed so far. After 500
milliseconds of time span since last keystroke, a new auto-edit
session begins where the previously typed characters are discarded
and new characters are used for multi-character matching.
Â
Â
Sent: Wed, 11 August, 2010 0:32:59
Subject: [Vantage] Re: 2D barcodes
Â
> The beauty about the ID Automation one is anyone on the network can run Crystal
>reports with the generated PDF417 barcode on them without having to pay for
>expensive licences or without having to install a font on every PC.
PMJI....
We have been using IDAutomation128 generated barcodes for travelers and starting
production activity with MES.
JobNum + tab + Assenmbly + tab + Operation + tab + tab + tab + carriage return
This has worked great on 8.03.305.
We recently upgraded to 8.03.409 and now, the Assembly field populates from the
bar code, and that's it.
When I scan the barcode into notepad, the tabs are still there.
So something is different on the MES entry screen but I haven't been able to
find it.
Any ideas?
Is anyone using 2D barcodes such as PDF 417 within crystal? If so who's
product do you use and what version of crystal are you using. The same
question goes for Code 128. I have a requirement to embed both types of
barcodes into a single shipping label. I know code 3 of 9 would be easy,
too bad our customer doesn't think so.
Thanks for the advice.
Keith Mailloux
Ferguson Perforating
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
Keith,
Check out IDAutomation. They will have everything you need.
http://www.idautomation.com
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
> Keith Mailloux
Yeah, BarTender is the bolt-on app from IdAutomation as Michael says.
Your Epicor rep can get it for you.
There are also plugins for Crystal Reports for 128. Check out
www.azalea.com
Vic
Of Michael Barry
Sent: Thursday, July 01, 2010 2:49 PM
Subject: Re: [Vantage] 2D barcodes
Keith,
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
who's
of
easy,
> Keith Mailloux
I have an unopened copy in a box here, premium shelf ware! It's yours
for a 30 pack of old Milwaukee.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Vic Drecchio
Sent: Thursday, July 01, 2010 2:20 PM
Subject: RE: [Vantage] 2D barcodes
www.azalea.com
Vic
Behalf
Of Michael Barry
Keith,
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
who's
of
easy,
> Keith Mailloux
I was curious for someone to explain me bartender if possible.
I'm looking to implement barcodes in the job traveler so the user can scan the jobnum and assy and mtl at once.
Since code 39 makes the barcode too long I was looking for datamatrix to do the job.
Also I want to print part labels with barcode but our partnum can be 30 characters long so a 2D barcode is preferable.
I was looking at IDautomation native barcode for crystal and it looks interesting but then I heard that Bartender is the way to go but I have no idea why and what this is.
Any help is appreciated.
Ephraim Feldman
Sender: vantage@yahoogroups.com
Date: Thu, 1 Jul 2010 14:55:03
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Rob Bucek
FAX: (715)284-4084
Of Vic Drecchio
www.azalea.com
Vic
Behalf
Of Michael Barry
Keith,
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
who's
of
easy,
> Keith Mailloux
We use "ID Automation" for our PDF417 - It is so easy to use.
They provide you with a 'sample' Crystal .rpt with a sample barcode in which you simply copy to your document and change what you want the barcode to read by either adding fields or formulas.
Â
Sent: Thu, 1 July, 2010 19:42:05
Subject: [Vantage] 2D barcodes
Â
Keith Mailloux
I really don't know what Bartender could offer that the ID Automation native font for Crystal doesn't.
I dont know for sure, but the ID Automation one I use only has PDF417 but we use it to join (with tabs and carriage returns) severl fields together at once.
We also use Bartender for a different application, but I don't think it is as easy and cost effective as the ID Automation solution.
The beauty about the ID Automation one is anyone on the network can run Crystal reports with the generated PDF417 barcode on them without having to pay for expensive licences or without having to install a font on every PC.
Sent: Fri, 2 July, 2010 1:37:01
Â
Ephraim Feldman
Rob Bucek
FAX: (715)284-4084
Of Vic Drecchio
www.azalea.com
Vic
Behalf
Of Michael Barry
Keith,
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
who's
of
easy,
> Keith Mailloux
run configeditor in client folder - on user tab try selecting select on enter checkbox and see if that does anything for you
> PMJI....
> We have been using IDAutomation128 generated barcodes for travelers and starting production activity with MES.
> We recently upgraded to 8.03.409 and now, the Assembly field populates from the bar code, and that's it.
> So something is different on the MES entry screen but I haven't been able to find it.
> Any ideas?
> Thanks
