2D Labels
Todd,
Check out the CR2 from code corporation:
http://www.codecorp.com
Their little reader waaayyyy outperforms the competition (symbol, intermec,
HHP, etc...) and has some very cool wireless options. The really cool part,
however, is their CodeXML BE router software that converts the data stream
into keystroke input at the host so integration with DC/IT screens is a
snap. For a nauseatingly thorough look at barcode fonts and their
implementation check out:
http://www.idautomation.com/fonts/pdf417/
Basically, the 2D Barcodes consist of two components: an encoder .dll to
create an intermediary data stream and a font to render the bar code. If
you are implementing in Crystal, installing the UFL (User Function Library)
creates a pair of functions that you can embed in a formula to encode the
data and render the barcode.
The benefits of 2D codes are enormous. First the data density far exceeds
1D codes like 3 of 9. For example you can encode the entire contents of a
standard shipping label (name, address, items, serial numbers, etc...) in an
area not much larger than a postage stamp. Second, 2D symbologies have
error correction built into the encoding/decoding algorithms so that even if
50% to 60% of the code is obscured of damaged, it can still be accurately
read. Third, they can be etched directly onto the finished goods and still
read effectively. Finally, since your scanner has to be an image scanner to
read the font, you can reuse the scanner to do things like take images of
defects for quality tracking, etc...
Good luck,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
This email, and any attachments thereto, is intended only for use by the
addressee(s) named herein and may contain legally privileged and/or
confidential information. If you are not the intended recipient of this
email, you are hereby notified that any dissemination, distribution or
copying of this email, and any attachments thereto, is strictly prohibited.
If you have received this email in error, please immediately notify me by
telephone and permanently delete the original and any copy of any email and
any printout thereof.
Todd Caughey
Sent: Wednesday, October 12, 2005 9:31 AM
Subject: RE: [Vantage] 2D Labels
Very interesting. We too just got some military work and the parts need to
be 2D serial number barcoded and components tracked under a master serial
number. Fortunately the customer is providing the labels so printing is not
an issue. Curiously they are using PDF417 as the format. Our only issue is
a scanner to record the component sets. We are probably going with an
Imageteam 4800 Industrial 2D Imager that used a CCD "camera" to view the
entire 2D barcode and resolve the data out of it. But down the road I can
see us having to print our own labels so that side is of great interest to
us too.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Michael Barry
Sent: Wednesday, October 12, 2005 10:51 AM
Paul,
As I'm sure you are finding out, the mil-spec 2D requirement is actually a
mixed spec requiring different symbologies for unit and intermediate
containers from the outer container. There are several software
applications that can meet the specification including:
http://www.barcoding.com/MIL-STD-129P.shtml
Of the available 2D symbologies the mil-spec is probably the weakest in that
it does not include error checking and cannot be direct etched on the
finished goods. As a result, there are more scanning errors with mil-spec
than say Data Matrix or PDF417. We're not aware of anyone who has directly
integrated mil-spec barcoding with Vantage but most of the available
labeling software claims to easily integrate with ERP applications.
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Paul Pachniak
Sent: Wednesday, October 12, 2005 7:30 AM
To: Vantage Group List (E-mail)
Subject: [Vantage] 2D Labels
We have to provide/create some 2D labels per spec MIL-STD-129P on a gov't
contract that we recently received.
I would appreciate any software suggestions and how you are getting the info
from Vantage to the label?
Also, is anyone doing RFD tags/labels, I suppose I should get ready in case
I need to provide those in the future.
Thanks!
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
Email: paul.pachniak@...
Phone: 1-262-252-4003 (ext 1114)
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION
OF ACE PRECISION MACHINING CORP. If you are an unintended recipient,
immediately (1) delete all copies of this message and any attachments, and
(2) contact the sender. If you are an intended recipient, you are
prohibited from deleting or obstructing this or any other Ace Precision
Machining Corp. proprietary or confidentiality designation that appears on
this message or any attachments. All recipients are prohibited from
reproducing, publishing or disclosing the contents of this message and any
attachments to others, unless you first request and receive written
permission from Ace Precision Machining Corp.
------------------------ Yahoo! Groups Sponsor --------------------~--> Get
Bzzzy! (real tools to help you find a job). Welcome to the Sweet Life.
http://us.click.yahoo.com/A77XvD/vlQLAA/TtwFAA/PhFolB/TM
Yahoo! Groups Links
SPONSORED LINKS
Manufacturing
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing
+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=P
da+database+software&w5=Database+management+software&w6=Database+marketing+s
oftware&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software Membership
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+softwar
e&w4=Pda+database+software&w5=Database+management+software&w6=Database+marke
ting+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+software&
w4=Pda+database+software&w5=Database+management+software&w6=Database+marketi
ng+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+
software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pd
a+database+software&w5=Database+management+software&w6=Database+marketing+so
ftware&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufac
ting+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufact
uring+software&w2=Membership+database+software&w3=Database+mortgage+software
&w4=Pda+database+software&w5=Database+management+software&w6=Database+market
ing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage>
" on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
_____
Yahoo! Groups Links
We have to provide/create some 2D labels per spec MIL-STD-129P on a gov't contract that we recently received.
I would appreciate any software suggestions and how you are getting the info from Vantage to the label?
Also, is anyone doing RFD tags/labels, I suppose I should get ready in case I need to provide those in the future.
Thanks!
Paul E. Pachniak
Accounting Manager
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
Paul,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Paul Pachniak
Thanks!
Paul E. Pachniak
Accounting Manager
Yahoo! Groups Links
Very interesting. We too just got some military work and the parts need to be 2D serial number barcoded and components tracked under a master serial number. Fortunately the customer is providing the labels so printing is not an issue. Curiously they are using PDF417 as the format. Our only issue is a scanner to record the component sets. We are probably going with an Imageteam 4800 Industrial 2D Imager that used a CCD "camera" to view the entire 2D barcode and resolve the data out of it. But down the road I can see us having to print our own labels so that side is of great interest to us too.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Michael Barry
Paul,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Paul Pachniak
Thanks!
Paul E. Pachniak
Accounting Manager
Yahoo! Groups Links
SPONSORED LINKS
Manufacturing <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software Membership <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software Database <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
