3.0 and 5.1 client on same machine
We have 3.0, 4.0, 5.0 and 5.1 loaded on the same server and accessible from
the same client, so it can be done. How to do it is a whole different
question. I would start with a clean play box, load one program at a time
and backup after each step, with enough patience you will have a semi stable
system. For version 5.1 do not use the standard service port, use some other
number. Hope this helps. Feel free to e-mail me offline.
Oleg Tumarkin
Intelligent Systems Integration
(330) 335-5291
olegt@...
"Making Intelligent Use of Technology"
Sent: Tuesday, December 18, 2001 3:22 PM
Subject: [Vantage] 3.0 and 5.1 client on same machine
Anybody figure out how to run both 3.0 and 5.1 on the same server yet? I
can get 5.1 to work but then 3.0 does not. Reinstall 3.0 and then 5.1 won't
work. I can't find anything in my saved messages on this.
Rick
Yahoo! Groups Sponsor
ADVERTISEMENT
http://rd.yahoo.com/M=178320.1681224.3270152.1261774/D=egroupweb/S=17050071
<http://rd.yahoo.com/M=178320.1681224.3270152.1261774/D=egroupweb/S=17050071
83:HM/A=879171/R=0/* http://www.fastweb.com/ib/yahoo-57f
<http://www.fastweb.com/ib/yahoo-57f> >
http://us.adserver.yahoo.com/l?M=178320.1681224.3270152.1261774/D=egroupmai
<http://us.adserver.yahoo.com/l?M=178320.1681224.3270152.1261774/D=egroupmai
l/S=1705007183:HM/A=879171/rand=832138527>
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
Your use of Yahoo! Groups is subject to the Yahoo!
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Terms of Service.
ADVERTISEMENT
83:HM/A=879173/R=0/*http://www.fastweb.com/ib/yahoo-76f>
l/S=1705007183:HM/A=879173/rand=569856487>
Rick
I am running 3.0 and 5.1 on the same server and have been for a few weeks
now. The only issue I had was with printing reports in 3.0 after I started
doing test prints in 5.1. As it turned out, the default working folder
c:\vntgwork was the same for 3.0 and 5.1. I reinstalled 5.1 with a
c:\vntgwk51 folder, and all is fine. The only other thing that I did was to
change the 3.0 shortcut to: V:\VANTAGE\Vantage.exe V:\VANTAGE\Vantage.vtg
This prevented it from being over written with the 5.1 install. I hope your
fix is this simple. Good Luck! - Les
> From: Rick Spriggle [SMTP:rspriggle@...]
> won't
> Thanks,
> Rick
> have already linked your email address to a yahoo id to enable access. )
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Rick,
This is a problem with 5.1 that is known by Vantage Support. I just
happened to notified of this by David Weiseth in Vantage Support while I was
discussing other migration issues with him. If you wish to call Support,
please feel free to reference call number 748367MPS.
Regards,
Scott A. Lepley
Systems Administrator
Mauell Corporation
31 Old Cabin Hollow Road
Dillsburg PA 17019-8815
Phone: 717-432-8686, ext. 14
Fax: 717-432-8688
Email: sal@...
Rick
Maybe I'm pointing out the obvious here, but did you go into Vantage and at
least print preview the reports that you want to modify? I've made the
mistake of trying to preview a report without creating the dbf files.
Ted Kitch
Misha1, LTD.
866-464-7421
Sent: Tuesday, December 18, 2001 3:29 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] 3.0 and 5.1 client on same machine
Rick,
Regards,
Scott A. Lepley
Mauell Corporation
Fax: 717-432-8688
Email: sal@...
Rick
ADVERTISEMENT
83:HM/A=879171/R=0/*http://www.fastweb.com/ib/yahoo-57f>
<http://docs.yahoo.com/info/terms/> Terms of Service.
