32 bit or 64 bit
Thanks Mark,
Can you do a spec sheet on the install and park it in Group files under a
"How To" header?
Robert Carlson
rcarlson@...
Mark Wonsil
Sent: Saturday, September 11, 2010 3:57 PM
Subject: Re: [Vantage] 32 bit or 64 bit
Robert wrote:
> There is no point with a 64 bit machine..you will need to install OE in 32
> bit in order to run E9. Currently Open Edge does not support 64 bit with
> E9.
> The entire Op sys will need to be 32 bit unless you find a way to have a
32
> bit environment running concurrently with a 64 bit environment so that you
> can run OE in 32 bit and E9 in 64 bit.
I have a Lenovo T510 with 8GB RAM running Windows 7 64bit. I run
VMWare Workstation running Windows 2008 Standard Server 64 bit. Epicor
9 in all of its 64 bit Open Edge glory runs in the virtual machine.
I'm installing 32 bit Open Edge in Windows 7 to run the
Admin/Conversion programs, which is the only part that doesn't run in
64 bit. Well, that and the ODBC drivers...
Without a 64 bit OS, it's difficult to get enough RAM available to run
Epicor 9.
Mark W.
I am wanting to purchase a new laptop to run Epicor 9. I am wanting to install the Demo Image as well. Epicor is sugesting a Lenovo, but I can get a Dell for less money and more features. I have an opinion about the Lenovo from my Epicor days. I understand I could have some difficulty accessing the AppServer with 64 bit. Just curious what this group thought about 32 bit vs. 64 bit?
Thank you,
Stephen
I have a dell precision m90 32 bit (xp pro) and run v8, v9 and v9.5 on
it with no problems.
My co-worker just got a new dell 64 bit laptop with same.
Of Snake
Sent: Saturday, September 11, 2010 12:56 PM
Subject: [Vantage] 32 bit or 64 bit
Thank you,
Stephen
64 bit what? Any processor you buy (except some of the low end Intel
Atoms) has the x86-64 instruction set. I'd get the 64 bit version of
Windoze for performance, and if things have problems run 'em in virtual
PC / VM ware / WinXP mode.
-w
E9.
The entire Op sys will need to be 32 bit unless you find a way to have a 32
Robert Carlson
rcarlson@...
Snake
64 bit?
Thank you,
Stephen
> E9.
Without a 64 bit OS, it's difficult to get enough RAM available to run Epicor 9.
Mark W.
