We're still testing 405a but the only problem we've seen is our
custom Pack Slip... resolved it by copying the missing OrderDtl Calc
fields from standard Pack Slip to the custom one.
Didn't know about the conversion fix.
--- In vantage@yahoogroups.com, Aaron Hoyt <aaron.hoyt@...> wrote:
> 1593284ESC - Packing Slip won't print "Invalid XPath selection
inside
> field node. Cannot find: mstns:Calc_PackNum." Support says run
> conversion 130.
> You will also find this conversion defaults all reports to Vantage
> standard and you will have to reattach any custom reports you might
be
> using.
> Best,
> Aaron Hoyt
> Vantage Plastics
> Charlie Wilson wrote:
> > All,
> > I went to the admin class a couple months ago. While I was there
I had ben
> > Nixon as the instructor he told us that after you install 405a
you have to
> > go run the conversion preprograms in admin tools but it doesn't
run
> > one that
> > it should. I know I wrote down which one you have to run but I
have
> > misplaced that note. Can some one remind me which conversion
program I
> > need
> > to run manually?
> > Charlie Wilson
> > IT Manager
> > Foam Design
