407C upgrade issue?
I thought about htat and if that was the case then why now? There are
some empty SalesRepList fields but the dates show that the records were
created yesterday, few days ago, and even last month. So why did it
error then? How is the field able to effect Crystal reports?
Of Steven Gotschall
Sent: Wednesday, May 27, 2009 10:54 AM
Subject: Re: [Vantage] 407C upgrade issue??
I would also suggest looking at the raw data in the field. Maybe they
changed the format of the rep list or maybe you are erring on NULL data.
<mailto:jeff.stockard%40rikerprod.com> >
Sent: Wednesday, May 27, 2009 1:48:23 PM
Subject: RE: [Vantage] 407C upgrade issue??
If this is a BAQ report, go into BAQ report designer. Generate Test
Data.
Open the Crystal report Create a new connection using the generated
data.
See if this fixes the Error.
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf Of
Dan Godfrey
Sent: Wednesday, May 27, 2009 1:36 PM
To: vantage@yahoogroups .com
None of the links were broken. I am able to run the BAQ but when we try
to generate the report, then we get the error. Do you have any other
suggestions. Thank you.
____________ _________ _________ __
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ]
On
Behalf
Of Jeff Stockard
Sent: Wednesday, May 27, 2009 9:43 AM
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
When we "Upgraded" to 407C, we had to re-establish some of the links in
some
of our BAQ's to get them to work. Go into the BAQ and click on the
phrase
builder link. Click on Next button. On the screen with the Table
relations, click on each Table relationship. As you go down the list of
related tables make sure that the Field Relations are correct. I don't
know
why this link is broken during "Upgrade", but it happens sometimes.
Jeff
<mailto:vantage% 40yahoogroups. com> ] On
Behalf Of
dgodfrey_amc
Sent: Wednesday, May 27, 2009 12:32 PM
Subject: [Vantage] 407C upgrade issue??
We just upgraded to 407c and have some issues. I created a BAQ-Report
through Crystal and it is ran multiple times a day. The day we upgrade,
our
report returns an error. Now I know the error CAME from Crystal but the
only
thing that changed was upgrading Vantage.
The error was regarding a formula in Crystal. I have a formulated field
to
split up the SalesRepList. So the code snippet is this:
split({BAQReportRes ult.OrderHed. SalesRepList} , '~')[1]
the error message is:
A subscript must be between 1 and the size of the array.
I understand the error itself, what I don't understand is why now? If
yesterday it works and today it does not and the only change is
upgrading to
407c, then how can Vantage effect a Crystal formula?
Can anyone help?
We just upgraded to 407c and have some issues. I created a BAQ-Report through Crystal and it is ran multiple times a day. The day we upgrade, our report returns an error. Now I know the error CAME from Crystal but the only thing that changed was upgrading Vantage.
The error was regarding a formula in Crystal. I have a formulated field to split up the SalesRepList. So the code snippet is this:
split({BAQReportResult.OrderHed.SalesRepList}, '~')[1]
I understand the error itself, what I don't understand is why now? If yesterday it works and today it does not and the only change is upgrading to 407c, then how can Vantage effect a Crystal formula?
Can anyone help?
When we "Upgraded" to 407C, we had to re-establish some of the links in some
of our BAQ's to get them to work. Go into the BAQ and click on the phrase
related tables make sure that the Field Relations are correct. I don't know
Jeff
dgodfrey_amc
Can anyone help?
Of Jeff Stockard
some
phrase
know
Jeff
Behalf Of
dgodfrey_amc
our
only
to
upgrading to
Can anyone help?
If this is a BAQ report, go into BAQ report designer. Generate Test Data.
Open the Crystal report Create a new connection using the generated data.
Dan Godfrey
Behalf
Of Jeff Stockard
some
phrase
know
Jeff
Behalf Of
dgodfrey_amc
our
only
to
upgrading to
Can anyone help?
I would also suggest looking at the raw data in the field. Maybe they changed the format of the rep list or maybe you are erring on NULL data.
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Dan Godfrey
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf
Of Jeff Stockard
some
phrase
know
Jeff
Behalf Of
dgodfrey_amc
our
only
to
upgrading to
Can anyone help?
