.409C Labor Entry Weirdness
Hi Vic; Unfortunately, don't have any solutions for you but we experince both #1 & #2 in 408. We don't worry too much about #1 since we use MES, but #2 becomes quite annoying when correcting labor entries that were not recorded correctly in MES.
Virginia Joseph
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...> wrote:
> I'm curious if anyone has seen this or duplicated this:
> In our .409C test environment, in Labor Entry, as we enter Labor Detail
> transactions for one Employee on the same payroll date, I see two things
> happening:
> 1) Only when the Shift spans midnight, as you enter multiple labor
> detail transactions on the left side in the "tree" as you enter new
> details, the new clock-in time auto-defaults to the previous clock-out
> time. That logic works on the 2nd detail transaction only. When I
> enter the 3rd detail transaction, it still uses the clock-out time of
> the *first* detail transaction instead of the second detail transaction.
> And all subsequent transactions still default to the clock-out time of
> the first detail transaction instead of the previous transaction.
> Again, this ONLY happens when the current shift for this record happens
> to span midnight. If the shift DOES NOT span midnight, the subsequent
> detail transactions work fine. I don't see the Labor Type making a
> difference, either. By the way, I've also seen this behavior duplicated
> in .408B (our current version).
> 2) A second problem: As you enter detail transactions, on the
> Labor Detail tab, in the top right corner, the "Labor" field accumulates
> as you enter transactions for that payroll date. In .408B, this works
> fine. In .409C this accumulation is NOT occurring. The Labor field
> remains at ZERO. It will update if I refresh the record, but I
> shouldn't have to do that after each labor detail transaction.
> Has anyone seen this and/or heard of an SCR?
> Thank you in advance.
> Vic
happening:
Vic
We've seen it and have compensated for it. Don't know of an SCR. We are just very cautious now on labor entry.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Monday, November 22, 2010 11:42 AM
Subject: [Vantage] .409C Labor Entry Weirdness
happening:
Vic
For what its worth, I noticed issue #2 in patch 409a.
Of Vic Drecchio
happening:
Vic
