I finally figured out what I needed for the BAQ calc - since it is looking for an expression only, this is what I came up with:
(IF RcvDtl.ReceiptDate >= PORel.DueDate - 3 and RcvDtl.ReceiptDate <= PORel.DueDate + 3
THEN "On Time"
Else (if RcvDtl.ReceiptDate < PORel.DueDate - 3
Then "Early"
Else (if RcvDtl.ReceiptDate > PORel.DueDate + 3
Then "Late"
Else "")))
What
I did'nt know about code in BAQs is the need for the parentheses
(progress code) - so my starting assumptions were wrong, hence some of
the frustrations!!
Kunal
Sent: Thursday, November 6, 2008 6:23:35 AM
Subject: RE: [Vantage] 4GL date calculation
Make sure you have the colons (:) and the periods (.) or it will not compile.
____________ _________ _________ __
From: vantage@yahoogroups .com on behalf of Kunal Ganguly
Sent: Wed 11/5/2008 5:02 PM
To: vantage@yahoogroups .com
Subject: Re: [Vantage] 4GL date calculation
I get a syntax error when i goto analyze it, do u have a very very simple working example that just prints something! this is especially frustrating because I am stuck due to a simple code syntax issue!!!!!!! !!
Kunal
From: Mike Anstey <manstey@flakeboard. ca <mailto:manstey% 40flakeboard. ca> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Sent: Wednesday, November 5, 2008 2:49:12 PM
4GL is a little picky...
IF condition 1 THEN DO:
END.
ELSE IF condition 2 THEN DO: (You can put in as many of these as you
want)
END.
ELSE DO:
END.
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of Kunal Ganguly
Sent: Wednesday, November 05, 2008 4:35 PM
if RcvDtl.ReceiptDate > PORel.DueDate - 3 and RcvDtl.ReceiptDate <
PORel.DueDate + 3
Then "On Time"
Else "xxxx"
need the rest of my conditions in there
Kunal
<mailto:dale. r.kalsow% 40determan. com> >
Sent: Wednesday, November 5, 2008 2:31:55 PM
Post what you have.
Behalf
Of Kunal Ganguly
Sent: Wednesday, November 05, 2008 2:27 PM
ok, i figured out the first if, but I am having trouble with the nested
if's. anyone got any pointers?
Kunal
<mailto:kunal_ vantage%40yahoo. com> >
To: Vantage Yahoo Group <vantage@yahoogroup s .com
<mailto:vantage% 40yahoogroups. com> >
Sent: Wednesday, November 5, 2008 1:52:01 PM
Subject: [Vantage] 4GL date calculation
Hello,
Need some help in 4GL on this time. I need to have a calculated field in
a BAQ that compares 2 date fields.
if date1 is within 3 days of date2 (i.e. +/- 3 days), then calculated
field (calc1) = "on time"
if date1 is less than 3 days before date2 then calc1 = "early"
if date1 is greater than 3 days after date2 then calc1 = "late"
for those familiar with receiving module, i am basically trying to write
a report for parts received against Purchase orders placed. I can see
the ontime field in the PO tracker under receipts, but i cannot for the
life of me find where it is stored, hence the calculations. According to
the zdata tables, there is a field called ontime in rcvdtl, but it does
not exist (ontime).
Kunal
THEN "On Time"
Then "Early"
Then "Late"
Else "")))
What
the frustrations!!
Kunal
Kunal
END.
want)
END.
ELSE DO:
END.
Of Kunal Ganguly
PORel.DueDate + 3
Then "On Time"
Else "xxxx"
Kunal
Post what you have.
Behalf
Of Kunal Ganguly
Kunal
Hello,
not exist (ontime).
Kunal
