Hello, I am struggling to convert a small piece of 4GL to C# I have used the online converter supplied by Epicor but I no’t know how to get the code to work, I have no C# knowledge.
I currently have a pre processing BPM on SalesOrder.ChangePartNum In Vantage 8.03.410 this looks at 2 fields and if there is data in them displays as a message in the sales order entry screen. I have changed the old UD filed to a new one for ERP10.
Original 4GL Code
find first ttorderdtl no-lock no-error.
if available ttorderdtl then do:
find first part where part.PartNum = ttorderdtl.PartNum no-lock no-error.
If available part then do:
if part.Character02 > " " then do:
{lib/PublishInfoMsg.i &InfoMsg = “part.Character02” }.
if part.PurComment > " " then do:
{lib/PublishInfoMsg.i &InfoMsg = “part.PurComment” }.
END.
END.
END.
END.
Converted C#
Erp.Tables.part part;
var ttorderdtl_xRow = (from ttorderdtl_Row in ttorderdtl
select ttorderdtl_Row).FirstOrDefault();
if (ttorderdtl_xRow != null)
part = (from part_Row in Db.part
where part_Row.PartNum == ttorderdtl_xRow.PartNum
select part_Row).FirstOrDefault();
if (part != null)
if (string.Compare((string)part[“Character02”] ," “,true)>0)
Lib.PublishInfoMsg(“part.Character02”);
if (string.Compare(part.PurComment ,” ",true)>0)
Lib.PublishInfoMsg(“part.PurComment”);
Also change Db.part to Db.Part, and change ice.lib.publishinomsg to this.PublishInfoMessage(“body of message”, Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, “FirstVar”,“SecondVar”);
First var and second var are just placeholders for your message box headers and such but you can r place the body of the message with any string you want.
I can help on Tuesday when I get back, but you have a nesting problem.
Your first if statement checks the length of the purcomment_c field. If this is true, it allows the second if statement to be executed.
Because the second statement is nested within the first, it will neve execute the second statement if the first one doesn’t pass.
Remember the statement inside the if statement only executes if the if condition returns “true”.
As far as the message contents, you are literally writing the string “purcomment” into it. If you want the field value, you will need to do something like part.PurComment.ToString() or part[“PurComment_c”].ToString() in there
Thank you that would be great, as i said I have no c# knowledge so even though I understand the issue with the if statement i don’t understand how to correct it
We are about to go Live in ERP10 this weekend so I won’t be able to do much now anyway, Tuesday sounds great in between my firefighting users on the GO Live day!!
Mark, here is your code formatted you can see that your Second message box is inside the if-statement of the is PartStatusComments_c if check.
Erp.Tables.Part part;
var ttOrderDtl_xRow = (from ttOrderDtl_Row in ttOrderDtl
select ttOrderDtl_Row).FirstOrDefault();
if (ttOrderDtl_xRow != null)
part = (from part_Row in Db.Part
where part_Row.PartNum == ttOrderDtl_xRow.PartNum
if (part != null)
if (string.Compare((string)part[“PartStatusComments_c”] ," “,true)>0)
PublishInfoMessage(“Part.PartStatusComments_c”,Ice.Common.BusinessObjectMessageType.Information,Ice.Bpm.InfoMessageDisplayMode.Individual, “123”,“456”);
PublishInfoMessage(“Part.PurComment”, Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, “FirstVar”,“SecondVar”);
Like Aaron was saying, if you are looking to do your if-statements independently then you should move the second statement be outside of the inner if-statement; your code will then look something like this.
if (part != null)
Hi Sorry for the delay getting back to you both regarding this,
Ken I have used the second set of code and this gives me the prompts when I expect them, thank for this.
Aaron, I can’t get your suggestion to work to bring back the actual data in the fields that I am referencing i just get the field names in the message box.
