4GL with Progress 9.1 - Delete all table contents
Ned, do you need the 8.03.400 D&L? I can email it to you. Email me
directly.
Otherwise, it's not difficult coming up with a "DELETE FROM xxxxx" script
listing every table. Query the zDataTable table for a list of tables and
concatenate a string together within the query's results to give you a
DELETE FROM for every table.
Ned
Sent: Thursday, July 25, 2013 5:01 PM
Subject: RE: [Vantage] 4GL with Progress 9.1 - Delete all table contents
I know it does for 8.03, but I only have the ASCII D&L Kit for version 6.1
on Progress 9.1.
Behalf Of
Calvin Dekker
Sent: Thursday, July 25, 2013 4:35 PM
Ned -
I believe if you follow the instructions in the binary dump & load, the
instructions have you create a blank database from the current database
structure.
HTH,
Calvin Dekker
Office: 630-672-7688 Ext. 1484
Email: calvin@... <mailto:calvin%40codabears.com>
<mailto:calvin@... <mailto:calvin%40codabears.com> >
http://www.codabears.com<http://www.codabears.com/>
[cid:image001.jpg@01CE894C.8A3C98F0
<mailto:image001.jpg%4001CE894C.8A3C98F0> ]<http://www.codabears.com/>
Solutions for Epiday living.
"No trees were harmed during the sending of this message, however a large
number of electrons were terribly inconvenienced."
Behalf Of
Ned
Sent: Thursday, July 25, 2013 3:25 PM
Subject: [Vantage] 4GL with Progress 9.1 - Delete all table contents
So, does anyone have any good ways to completely blank a database in
Progress 9.1?
I am working on a project to do a dump and load, but I can't use the
standard empty database because the customer has some custom tables, fields,
and indexes, and if I manually recreate them then there ends up being a CRC
mismatch with the program.
I know I can manually write out a script to clear the contents of each table
individually, but if I can save my own time, and save them some money if
someone has already done something like this?
I will probably be using either the truncate or the delete command, I am
just not sure if there is an easier way to do all tables versus wiring them
all out one by one in a script.
I would look to Epicor, but there is no maintenance contract anymore, so
it's not an option to work with them.
Progress 9.1?
Ned -
I believe if you follow the instructions in the binary dump & load, the instructions have you create a blank database from the current database structure.
HTH,
Calvin Dekker
Email: calvin@...<mailto:calvin@...>
[cid:image001.jpg@01CE894C.8A3C98F0]<http://www.codabears.com/>
"No trees were harmed during the sending of this message, however a large number of electrons were terribly inconvenienced."
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ned
Progress 9.1?
on Progress 9.1.
Calvin Dekker
Ned -
structure.
HTH,
Calvin Dekker
Ned
Progress 9.1?
