5.0 Ready?
Sent: Thursday, February 22, 2001 12:20 PM
Here it is... I'm sure there's others but this is all I
have kept track of. None of these are fixed except
possibly for the data collection issue. I haven't
installed patch 310 yet. Patch 310 only had three fixes.
unknown date
aps Setup time field missing from part methods
666102
unknown date
Purchase order does not change from NEW to CHANGE when the
PO is modified.
664107
2-12-01
Must turn off all shop warnings to make data collection work.
652705
2-13-01
JOE:
NEW INVENTORY USAGE REPORT HAS A BUG. PART CLASS SELECTION DOES NOT
WORK.
GIVES MORE THAN THE CLASS SELECTED.
665612
2-14-01
Entering a prefix in UNFIRM in comp config doesn't allow MRP to run.
If you don't enter a prefix MRP will run. In either case the
job number is 14 digits long.
MRP crashes when job number already exists.
666086
2-15-01
Part tracker and part maint - When you type a part in start-at then hit
enter
twice, the cursor is stuck at "view inactive parts".
2-15-01
Labor edit report does not show idle time when run by department. This
problem has existed since v4.
665560
2-15-01
PO unit of measure is incorrect in purchasing suggestions.
MAJOR PROBLEM!!!!
666976
2-16-01
When adding a sales order release the make direct flag is stuck on
even on stock parts. This only happens on orders that existed on v4.
667332
2-20-01
JOE:
PROBLEM WITH TRYING TO DUPLICATE A PO IN PURCHASE MGMT.
WHEN DUPLICATING A CLOSED PO, THE NEW PO LINE ITEMS ARE ALSO CLOSED AND
IT
WILL NOT LET YOU DELETE ANY OF THE LINES YOU DO NOT WANT.
GARY
A similar issue has been reported with a PO line's job number, but SCR
1722,
fixed for Vantage 5.00.311, resolves this issue as well. The problem is
that when you duplicate a PO, the PO lines on the screen are still from
the
old PO.
667995
2-22-01
Data collection does not force you to select a discrepant reason if you
report a discrepant qty.
668792
I notice patch 310 is now available. Does anyone know if
5.0 is patched enough to rely on? Are the major bugs fixed?
Or should we wait a while longer? Really like some of the new
features.
Bob Bruton
Entek Corp.
I'm going to install it soon for testing. I have a list of
bugs that I found that I can post if you would like.
> features.
> Bob Bruton
> Entek Corp.
> To unsubscribe from this group, send an email to:
> vantage-unsubscribe@egroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I'm interested in this list, if you don't mind :)
Jamie
Jamie Copsey
Database Administrator
AMF Electronics / Accurate Metal Fabricators
1011 Seal Beach Blvd
Seal Beach, CA 90704
(562) 596-4740 x138
Fax: (562) 596-6799
jcopsey@...
> -----Original Message-----
> From: Joe Konecny [SMTP:jkonecn@...]
> Sent: Thursday, February 22, 2001 9:07 AM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] 5.0 Ready?
Joe,
I've been following your pioneering efforts with 5.0 so I would be very
interested in your assessment of the latest patch.
Best regards,
Jerry Solobay
IS/IT Manager
Ebco Aerospace
8510 River Road
Delta, BC, Canada V4G 1B5
unknown date
666102
unknown date
PO is modified.
664107
2-12-01
652705
2-13-01
JOE:
WORK.
665612
2-14-01
666086
2-15-01
enter
2-15-01
665560
2-15-01
MAJOR PROBLEM!!!!
666976
2-16-01
667332
2-20-01
JOE:
IT
GARY
1722,
the
old PO.
667995
2-22-01
668792
> Thanks,
> Jamie
> Jamie Copsey
> (562) 596-4740 x138
> Fax: (562) 596-6799
> jcopsey@...
I would like the list as well. Thanks.
Dick Salonek
UMC
Sent: Thursday, February 22, 2001 11:07 AM
> features.
> Bob Bruton
> Entek Corp.
Thanks for the list Joe.
Now it's decision time. If I understand the data collection problem
correctly, it only
affects terminal server / remote site data collection.
Also thanks for all the testing you've done. Some of us don't have the
resources to
do extensive testing on each new release. We have to rely on Epicor to
supply thoroughly
tested and debugged software.
I don't know for sure but I suspect it affects any data collection
system terminal server or not. I think the more users you have
using the system the more likely the problem will show up. If you
never have two users generating a transaction that creates a shop
warning at the same time you may get lucky. I know a guy who has
7 users who runs it with pretty good luck. I have 60 to 100 guys
using 35 terminals and we crashed constantly till we turned off
shop warnings.
> correctly, it only
> resources to
> supply thoroughly
> From: Joe Konecny [mailto:jkonecn@...]
I'm interested in this list as well.
Sent: Thursday, February 22, 2001 9:09 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] 5.0 Ready?
Jamie
Jamie Copsey
(562) 596-4740 x138
Fax: (562) 596-6799
jcopsey@...
I posted it several hours ago.
> Thanks
> From: Copsey, Jamie [mailto:jcopsey@...]
> Thanks,
> Jamie
> Jamie Copsey
> (562) 596-4740 x138
> Fax: (562) 596-6799
> jcopsey@...
Joe, I am in Yahoo Groups now and don't see it. I see your posting for aiag
shipping labels, but not the listing. Am I in the right area? I am looking
in the files for downloading
Sent: February 22, 2001 3:01 PM
> Thanks
> Thanks,
> Jamie
> Jamie Copsey
> (562) 596-4740 x138
> Fax: (562) 596-6799
> jcopsey@...
That's because I posted it to the list as a message. Check your
inbox.
> > Thanks
> > Thanks,
> > Jamie
> > Jamie Copsey
> > (562) 596-4740 x138
> > Fax: (562) 596-6799
> > jcopsey@...
