For anyone having trouble with the schema change... there is
a fast schema change procedure available from epicor. You'll
have to call support and ask for it.
Tim Care wrote:
> Rick,
> In trying to convert our db on a test system, we ran into
> the same problem. What we ended up doing was running
> the conversion on the server, and changing the connect options
> in the schema change vtg file to -1. You do need to have
> provision in order to do this. Support can talk you through the
> setup of the vtg file. Hope this helps. Good luck.
> Tim Care
> Electro Chemical Finishing
> From: "Rick Spriggle" <rspriggle@...>
> To: <vantage@yahoogroups.com>
> Sent: Monday, March 05, 2001 7:17 AM
> Subject: [Vantage] 5.0 Schema Changes
> > Currently we are on 3.00.632 and have an approximately 1gb database. This
> > spring we would like to jump right to 5.0. I did the conversions to 4.0
> on
> > a test server and it amounted to about a days worth - manageable - and the
> > database grew to 1.2gb. Now I'm doing the 5.0 schema changes and it has
> > been running since 1:00pm last Thursday, 90 hours on the task manager cpu
> > counter! Yes, I have crash protection turned off or at least I think I
> do.
> > This was the part where Epicor's installation instructions for Progress
> > Explorer really fell short and I had to use the online help.
> > What has anybody else with a large database done to get around this? I
> > remember a discussion earlier in the year about connecting as a single
> user
> > to run the schema changes. Assuming we were already live on 4.0 and that
> > step was out, what am I supposed to do to upgrade, tell the plant to shut
> > down for a week? Any suggestions are welcome.
> > Thanks,
> > Rick
> > PS - And Epicor wonders why we are still on 3.0.
> > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
