5.1 - Material Burden
We have been using material burden under 5.0 since February. Since we
had burdened material prior to moving to Vantage a couple of years
ago, we were anxious to implement this after we finally upgraded from
3.0 last year but it is not working out as well as we had hoped.
In a nut shell, if you add a material burden % to a partmaster item,
the burden will be added to the cost at the time of receipt,
crediting the designated Material Burden Applied account.
Unfortunately for us, a large percentage of our purchase are custom
material bought directly to jobs, without using the partmaster. In
this case, no burden is applied to the material.
• Rob McFarlin, CPA, Controller
• Accel Group, Inc.
325 Quadral Dr.
Wadsworth, OH 44281
• (330)336-0317 x114
• FAX(330)336-1224
• RobM@...
--- In vantage@y..., "DODD, Jim" <jimd@l...> wrote:
> I am rather interested to know if anyone is using the Material
Burden
> function and if you could explain how it works via an example. The
help
> function does not tell me much on the specifics.
> This is a feature that if it works the way I hope it works would
eliminate
> quite a bit of off-line costing for us.
> Thank you in advance,
> Jim Dodd
> La Calhene, Inc.
I am rather interested to know if anyone is using the Material Burden
function and if you could explain how it works via an example. The help
This is a feature that if it works the way I hope it works would eliminate
Jim Dodd
La Calhene, Inc.
