5.1 PO Form
Thanks! I tried this and it worked.
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Monday, February 04, 2002 1:35 PM
Subject: RE: [Vantage] 5.1 PO Form
We use crystal 8.5 and I now always save my reports as version 7 and I
don't
have any of the issues I was having when I saved them as crystal 8.5.
We're
on 5.0.
Just converted to 5.1 from 4.0 this weekend. What an "Epic"!
Everything went pretty well actually (knock on wood). I do have a
question that hopefully others on 5.1 have seen. I have Cyrstal 8.5.
When I modify the PO Form and I do a preview I can see all the fields:
Due Date, Quantity, Etc. When I preview or print the same PO in Vantage
these fields are gone. I have set my locations and verified my
database, etc. If I hadn't I wouldn't even be able to preview the form
in Crystal. Any suggestions or clues to why this is?
Juliet
I have had major issues with CR 8.5. I contacted CR and I was able to get
an upgrade from my 7.0 to 8.0 for a pretty small fee. Also, I received my
CDW volume licensing catalog and they are also still advertising v. 8.0
professional for $325 (1 user), although I couldn't find it on their site.
All of my problems disappeared after installing 8.0, opening reports and
saving them in 8.0 (which is the only version Epicor supports)
HTH,
Paul
Sent: Monday, February 04, 2002 12:56 PM
Subject: [Vantage] 5.1 PO Form
Juliet
Before backing down to 8.0 you could try copying the cr*.dll file found in
vantage\dll from your PC (where you preview using CR) to the Vantage\dll
folder (after renaming the ones there to preserve them). There are a couple
files in the vantage dll folder but the main one (that worked for me) was
crpe32.dll. They need to match between the development PC and Vantage.
This might not fix your issue but it is easy to try just in case before
obtaining 8.0 and doing the uninstall of 8.5. Of course there may be other
8.5 issues as well which cause it to be not supported by Epicor.
-Todd C.
Sent: Monday, February 04, 2002 12:06 PM
To: 'vantage@yahoogroups.com'
HTH,
Paul
Juliet
<http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=218512.1856015.3360178.1269402/D=egroupweb/S=17050071
83:HM/A=928901/R=0/*http://ad.doubleclick.net/clk;3788034;6800959;v%3fhttp:/
/www.verisign.com/cgi-bin/go.cgi?a=b228473240057000>
<http://us.adserver.yahoo.com/l?M=218512.1856015.3360178.1269402/D=egroupmai
l/S=1705007183:HM/A=928901/rand=482953807>
In my troubleshooting endeavors I was advised by Epicor to replace the
following .DLL's (in addition to the crappy32.dll mentioned by Todd):
crpaig32.dll & p2bxbse.dll, which you might want to include...
Paul
Sent: Monday, February 04, 2002 1:42 PM
-Todd C.
HTH,
Paul
Juliet
ADVERTISEMENT
Have you tried viewing the report on a machine that does NOT have CR 8.5? If it works on other machines, then CR 8.5 is the culprit (as it only affects the machine with the incorrect .dll's on it) If other machines can see the fields fine, I would just let it go (which is what we did) and know not to run that report from the CR 8.5 machine.
Another thing to check... just so as to not overlook the obvious... Did you change the report in "Report Style Maintenance" to use your modified report instead of the Standard Vantage report?
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Monday, February 04, 2002 12:55 PM
Juliet
ADVERTISEMENT
We use crystal 8.5 and I now always save my reports as version 7 and I don't
have any of the issues I was having when I saved them as crystal 8.5. We're
on 5.0.
