No problem. running the re-index isn't that big of a deal, but does tend to
mess up a good weekend. We just finished doing a dump and load of the
datbase here, which includes running the idxbuild utility. On a 4GB
database it took about 3.5 hours to run.
Paul
Sent: Wednesday, August 18, 2004 8:15 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] 5.2 Error when deleting sub-assembly
Thanks for the help, Paul! At least I know what I could be possibly
facing....
Sent: Wednesday, August 18, 2004 9:06 AM
Paul,
I found this on the epicor support site.
Page ID 1723MPS
PROBLEM DESCRIPTION:
Getting a "SYSTEM ERROR: proixdel failed for word indexing of array
(2699)" trying to update a record, for example a part description on a PO.
User then gets kicked out of Vantage.
RESOLUTION:
This is a Progress error, and usually indicates some type of data
corruption, possibly a bad record. Reindexing the database (see seperate
instructions) should take care of the problem.
According to Progress documentation:
SYSTEM ERROR: proixdel failed for word indexing of array (2699)
An unexpected system error has occurred. Please do the following:
1. If the error occurred while running an existing application or
during database admin functions, the error may be due to a
hardware/system problem, r-code corruption, or data corruption.
Note what was processing during the time the error occurred.
Check your system error logs and Progress database log file for
any additional errors.
2. If the error occurred while running a new application or
procedure,
try to reproduce and isolate the code that results in the error.
3. Search the on-line Progress knowledgebase for information on the
error. The kbase can be accessed via the Progress web site at:
http://www.progress.com or
http://www.progress.com/services/techsupport/online.html
4. If the above does not lead to resolution, please contact your
dealer (VAR) who sold you PROGRESS, or the Progress Technical
Support center for your region.
Sent: Wednesday, August 18, 2004 7:30 AM
Subject: [Vantage] 5.2 Error when deleting sub-assembly
Has anyone seen the error below before? One of our engineers is trying
to
delete a subassembly and gets this error. After he clicks OK to clear
it,
Vantage kicks him out. I tried to get into the Answerbook but it seems
to
have problems...
Error
OK
Thanks!
Paul
and
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
have
Yahoo! Groups Links
ADVERTISEMENT
Yahoo! Groups Links
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Paul
facing....
Paul,
Page ID 1723MPS
RESOLUTION:
procedure,
to
it,
to
have problems...
Error
OK
Thanks!
Paul
and
ADVERTISEMENT
Yahoo! Groups Links
Service.
have
Yahoo! Groups Links
ADVERTISEMENT
Yahoo! Groups Links
