5.2 Project Management Performance
Does anyone else find Project Management PAINFULLY slow to use? It takes
minutes to switch from Open to Closed POs, and then you can't multiple
select lines within it, so you have to repeat the process for each one. I'm
wondering if this is a problem within Vantage or ???
Thanks!
Rebecca
