We are using the misc charge on the line, adding it to the last line. I (temporarily) modified the Crystal report to suppress "Line x" on the misc charges section of the report.
--- In vantage@yahoogroups.com, "advantage" <advantage@...> wrote:
> Has anyone experience or know the work around for the following: Since SCR
> 54405 is logged for this issue and the SCR doesn't have a target until
> service pack 505.
> The SCR does not have a work around noted.
> When changing or entering a misc charge on the Sales order header screen the
> following message came up:
> Exception caught in: Epicor.Mfg.BO.SalesOrder
> Error Detail
> Message: Unexpected error - see appserver logs.
> Type: Error
> Program:
> Method:
> Table:
> Row:
> Field:
> Stack Trace
> at Epicor.Mfg.Proxy.SalesOrderImpl.ChangeMiscAmount(SalesOrderDataSet ds,
> String tableName)
> at Epicor.Mfg.UI.Adapters.SalesOrderAdapter.ChangeMiscAmount(String
> tableName)
> Inner Exception
> ERROR condition: The Server application has returned an error. (7243) (7211)
