Dan,
Sorry for not responding earlier. We jumped from 5.0 to 6.0 on a
clean server. I installed it so that the Progress installation was
on the same share as the Mfgsys portion.
My server looks like this v:\ =Epicor on VntgServer
I have a path v:\mfgsys60 with all of the Vantage files.
I have a path v:\prgs91d with all of the Progress files.
I seem to remember an option in the instructions where you could use
the existing 5.2 installation of Progress or install it on the same
share. Since I was never using 5.2 I chose to set it up like this.
Brian Stenglein
Clow Stamping Co.
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "Dan Clifton" <dclifton@n...> wrote:
> Yeah, I was going to jump from 5.1 to 6.0 this week-end and was
kind of
> confused with the 5.2 to 6.0 upgrade instructions. So basically you
have
> to use the Progress portion of 5.2 and MFGSYS from the Epicor 6.0
folder
> and they both have to exist together and use 2 mapped drives for the
> clients? What's up with that? Did everyone do it this way? Can you
not
> just use one shared folder for this that contains the Progress and
> Vantage Files?
> Please advice,
> Dan Clifton
> -----Original Message-----
> From: Brian Stenglein [mailto:bstenglein@c...]
> Sent: Thursday, May 27, 2004 12:12 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: 6.1 & 6.0 Upgrade Utility
> I upgraded to 6.0 in November and I had a problem using the
utility,
> don't remember what exactly, but I had to do things manually also.
> Brian Stenglein
> Clow Stamping Co.
> --- In vantage@yahoogroups.com, "Edward F. Fox, Jr." <efox@m...>
> wrote:
> > I just finished leap frogging my 5.0 database up to 6.1. I had a
> problem
> > with the new upgrade utility that started at 6.0.
> > I ran the utility and it made a copy of the db and then I got an
> error the
> > the DLC env. variable must have a valid dir/path. I'm not sure
> why, but
> > after I did things manually it worked.
> > I'm just curious if anyone else experienced this issue.
> > Edward F. Fox, Jr. CPA
> > Controller
> > Maxson Automatic Machinery Company
> > Phone 401-596-0162 * Fax 401-596-1050
> > www.maxsonautomatic.com <http://www.maxsonautomatic.com/>
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> Yahoo! Groups Links
