[6.1] byproduct manufactuting
We have the same manufacturing scenario where we do by-products/co-products as our SOP- We do a sales order jobs (3999-9-9 numbered jobs with one set of actions for the finished product and we have independent one off jobs (1000 numbered jobs where we use Vantage to sequentially generate the numbers for us) that we have to tie back into operations on the sales order jobs. You can either do jobs to receive into the sales order jobs or opt to build the second set of jobs to inventory and then issue the by-product/co-product from inventory into the sales order jobs to mate into the finished product step as a material requirement. The trick here is to schedule and link these jobs with each other and will require the production mgr to keep a tight rein on jobs in the air at any given time. Its a challenge for us now and we are looking to optimize this process further.
----- Original Message ----
Sent: Thursday, August 30, 2007 6:35:38 AM
Subject: RE: [Vantage] [6.1] byproduct manufactuting
My only suggestion in these matters has always been to run the 2 jobs
(or subassemblies) parallel. An example is a right and left from the
same material at the same time followed by the mating of the parts. Assy
1 makes the right. Assy 2 makes the left and assy 0 puts them together.
Each Assy has its own part ID (1234L and 1234R go into making 1234) and
MOM. The Stamping ops J9876/1/10 and J9876/2/10 are clocked in and run
together. The assembly op (J9876/0/10) mates the two parts.
It's the only solution I have ever been able to come up with.
Charlie Smith
Smith Business Services / 2W Technologies LLC
www.vistaconsultant .com <http://www.vistacon sultant.com/> /
www.2WTech.com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Bruce Butler
Sent: Thursday, August 30, 2007 8:13 AM
To: vantage@yahoogroups .com
Subject: [Vantage] [6.1] byproduct manufactuting
The issue comes up every so often: 2 parts are manufactured out of one
piece of raw stock. This time it is a situation where one part is the
mating part for another. The limitation I run into is the job can only
be setup with one part number. I looked at the "salvage" material for
answers, but this doesn't fit the bill. That seems to work only for Raw
stock / material items.
Any suggestions?
Bruce Butler, IT Manager
Knappe & Koester, Inc. <http://www.knappe- koester.com>
18 Bradco Street
Keene, NH
p. 603-355-1166
f. 603-355-2266
bbutler@knappe- koester.com <mailto:bbutler% 40knappe- koester.com>
The information in this message is proprietary and/or confidential and
is intended only for the use of the individual(s) named above. This
message should not be forwarded without permission from the author. If
this message is received in error or otherwise by someone other than the
addressee, please contact the author at the above number and return the
message or destroy it. In addition, the recipient of this data agrees to
abide by the United States Export Control of Technical Data and
Equipment under the International Traffic in Arms Regulations (ITAR) and
Export Administration Regulations (EAR). The recipient agrees to abide
by these laws and their regulations not only for export and re-export,
but for disclosure to non-U.S. citizens.
____________________________________________________________________________________
Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center.
http://autos.yahoo.com/green_center/
Any suggestions?
Knappe & Koester, Inc. <http://www.knappe-koester.com>
18 Bradco Street
Keene, NH
p. 603-355-1166
f. 603-355-2266
bbutler@...
In Vantage 8.0 they have added the advanced production module, you can
have multiple finished parts on the job header. I do not think it is
available in 6.1 though?
Salvage doesn't quite work because you can only have one salvage part
per material
Gary Parfrey
Dot Net IT Limited, Reg No 4412519
Of Bruce Butler
Sent: 30 August 2007 13:13
Any suggestions?
18 Bradco Street
Keene, NH
p. 603-355-1166
f. 603-355-2266
bbutler@... <mailto:bbutler%40knappe-koester.com>
Charlie Smith
www.vistaconsultant.com <http://www.vistaconsultant.com/> /
www.2WTech.com
Of Bruce Butler
Any suggestions?
18 Bradco Street
Keene, NH
p. 603-355-1166
f. 603-355-2266
Gary, I just saw your response on this. we are on V8 and I am not sure if we have APS or not- how can you tell?
I'm curious can you elaborate further on how you do multiple finished parts on the job header?
Thx
RSN
Sent: Thursday, August 30, 2007 6:22:28 AM
per material
Gary Parfrey
Of Bruce Butler
Any suggestions?
18 Bradco Street
Keene, NH
p. 603-355-1166
f. 603-355-2266
Pinpoint customers who are looking for what you sell.
http://searchmarketing.yahoo.com/
Its not APS (Advanced Production and Scheduling), its Advanced
production.
If you look in Vantage Admin tool, under your license configuration it
is in there under 'Advanced Production'. It will tell you whether it is
installed or not. Or look at your license document and look for the
same.
The module does job parts and the ability to batch operations and the
like.
Gary
Of RSN
Sent: 06 September 2007 23:43
Subject: Re: [Vantage] [6.1] byproduct manufactuting
Thx
RSN
From: Gary Parfrey <garyp@... <mailto:garyp%40dotnetit.co.uk>
per material
Gary Parfrey
Behalf
Of Bruce Butler
Any suggestions?
18 Bradco Street
Keene, NH
p. 603-355-1166
f. 603-355-2266
I believe, in v6 you can salvage more than one part per material on a
manual basis. However, this cannot be defined in the MOM/BOM and is
quite messy from a procedural point of view. Also there are some cost
restrictions on this through the salvage process. Depending on your
costing model it could cause problems.
As an aside, the salvage process does not include a serial number
tracking/entry. This has to be done through part maintenance.
can
is
part
> per material
> Gary Parfrey
Behalf
> Of Bruce Butler
one
the
only
for
Raw
> Any suggestions?
> 18 Bradco Street
> Keene, NH
> p. 603-355-1166
> f. 603-355-2266
and
If
than the
the
agrees to
(ITAR) and
abide
export,
ok- so we don't have it. So how is it possible to do multiple parts at the job header. can you send me a snapshot of what the job header screen looks like for you.
thank you
RSN
Sent: Thursday, September 6, 2007 4:59:59 PM
production.
same.
like.
Gary
Of RSN
Thx
RSN
From: Gary Parfrey <garyp@dotnetit. co.uk <mailto:garyp% 40dotnetit. co.uk>
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
per material
Gary Parfrey
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
Behalf
Of Bruce Butler
Any suggestions?
18 Bradco Street
Keene, NH
p. 603-355-1166
f. 603-355-2266
____________ _________ _________ _________ _________ _________ _
http://searchmarket ing.yahoo. com/
Moody friends. Drama queens. Your life? Nope! - their life, your story. Play Sims Stories at Yahoo! Games.
http://sims.yahoo.com/
