[6.1]Crystal Rpt export crash
An update - not installing 2 of the patches corrected the export crash
(still working without crashing) but it appears to have had an interesting
side effect (like a lot of drugs these days that fix one thing but may cause
other problems)- when printing job travelers, my workstation prints the
operation details on only Assembly level 0 - no operation details on any
other level. go figure.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Norm Watkins
Sent: Friday, June 15, 2007 11:05 AM
Subject: RE: [Vantage][6.1]Crystal Rpt export crash.
At Steve's suggestion, I uninstalled CR, made sure all the files were gone -
including registry files, reinstalled CR, without the Epicor patches, and at
least for now it is working (20 exports in a row). I then installed the
report distribution patch, and still have no problems - so it's working
without installing 2 of the 3 Epicor patches.
FYI, I am using CR 8.5
Of Steve Mulder
Sent: Friday, June 15, 2007 7:14 AM
I would try to not have all the patches installed. A service pack gave
me a lot of grief when we updated our version of crystal last year.
I would say give it a shot with a fresh install off the crystal cd, and
see if the problem still persists. Then at least you will know a little
bit more about where your problem might be.
Steve Mulder
Information Systems
712-324-4854 x1196
Of Norm Watkins
Sent: Friday, June 15, 2007 8:49 AM
To: Vantage@Yahoogroups. Com
Subject: [Vantage][6.1]Crystal Rpt export crash.
I just recently got a new pc and installed CR and all the patches , but
my
exports from CR to Excel is causing CR to crash intermittently.
Sometimes I
can export several times successfully, but then it crashes. Re-opening
CR I
can export successfully the first time, but after that is anyone's guess
if
it works or crashes - and it doesn't matter whether I overwrite a file
or
export to a new file.
I've uninstalled and reinstalled CR several times with the same results.
The old PC still works flawlessly.
Any ideas?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Yahoo! Groups Links
Yahoo! Groups Links
I just recently got a new pc and installed CR and all the patches , but my
exports from CR to Excel is causing CR to crash intermittently. Sometimes I
can export several times successfully, but then it crashes. Re-opening CR I
can export successfully the first time, but after that is anyone's guess if
it works or crashes - and it doesn't matter whether I overwrite a file or
Any ideas?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Steve Mulder
Information Systems
712-324-4854 x1196
Of Norm Watkins
my
Sometimes I
CR I
if
or
Any ideas?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
I know Epicor doesn't necessary recommend installing all the service
packs..I've seen in some instances where they only want you to run a
certain version of Crystal forever...8.5, etc.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
317.578.2393
jason@...
Of Norm Watkins
Sent: Friday, June 15, 2007 9:49 AM
my
Sometimes I
CR I
if
or
Any ideas?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
I didn't install any of the service patches, just the export patches
downloaded from eipcor for CR 8.5
Of Jason Claggett
Sent: Friday, June 15, 2007 7:19 AM
Jason Claggett
MCP #3856159
317.578.2393
jason@...
Of Norm Watkins
my
Sometimes I
CR I
if
or
Any ideas?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Yahoo! Groups Links
Hi Norm,
I have the same problem also. I haven't found a solution that has completely fixed the problem, or even isolated the cause. One thing that does seem to work for me when it acts up, is to run/refresh the report, save the report, exit Crystal, reopen the report and then export without refreshing. Also, I have always been able to export to a CSV file, and then convert (a pain sometimes, depending on the report).
Liz
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Norm Watkins
Sent: Friday, June 15, 2007 06:49 AM
Any ideas?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Of Steve Mulder
Steve Mulder
Information Systems
712-324-4854 x1196
Of Norm Watkins
my
Sometimes I
CR I
if
or
Any ideas?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Yahoo! Groups Links
