Thanks all for the help.
I found the odbc parameters were not remarked out in theMfg startup file
on the pcs having trouble. After remarking these out and deleting all
files in their vantage working directorys they were able to print
preview and print purchase orders. I had also set up a std form and
print previewed it, opened the custom crystal form and set location to
the same tables in the c:vantage working directory and set the custom
form as default in report stlyes. Its all good now.
thanks again
dennis
thanks again
dennis
> If you already modify the vantage.mfg file in the mfgsys61 directory
> with the MFGODBC statements in the bottom of this file, you may want to
> review the ODBC connection of the client and verify that the user can
> connect to Vantage using ODBC alone before starting Vantage.
> A quick fix while troubleshooting is to revert to the original PO report
> which requires only .dbf files.
> Mario E. Aguirre - IT Manager
> Lakin General Corporation, Inc.
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>] On
> Behalf
> Of Dennis Houghton
> Sent: Monday, February 26, 2007 10:26 AM
> To: vantage
> Subject: [Vantage] 6.1 odbc/crystal forms
> We recently installed odbc and the fix kit over the weekend, now we get
> error '0' when we print preview a puchase order prior to printing. I
> have done the procedure from my pc to delete temp files in the mfgwork
> folder on c:, print preview a standard form and then set location to
> each table on the custom form and works ok on my pc which is the pc that
> odbc is set up on but get error '0' on other workstations. Can someone
> help me on this please, can't get through to tech support.
> thanks
> dennis
