After you create the view, you need the do the "GRANT SELECT ON "view
name" TO "user name"" statement in your SQL Explorer.
--- In vantage@yahoogroups.com, Todd Caughey <caugheyt@...> wrote:
> Well....I had a small slot of time last night between 12:15am when
2nd shift had all gone and 1am when the Vantage backup kicks in. I
ProMon disconnected everyone and just to be sure stopped the DB and
set the users to as low as it would let me and restarted the DB
(reversed all this later). I could then create the view without an
error message but when I remoted into another server with Access it
could not see the external data source I had named. It may have been
the ODBC setup on that or an issue with my Citrix desktop remote
session so I will try it here in the office today and see if it
appears. Thanks for all the suggestions.
> -Todd C.
Behalf Of saab_barracuda
> Sent: Tuesday, August 19, 2008 7:09 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: [6.1] ODBC View on Customer table -
Exclusive Access
> I start with Vantage Admin Tools and kill all sessions (including
> MES). Then log into PET and stop the all three app servers. You
> need the database running to connect into SQL Explorer so leave that
> alone. After you stop the app servers you should have exclusive
> access. You may want to add these steps to your copy of the ODBC kit
> document for next time.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>,
Todd Caughey <caugheyt@> wrote:
> > When trying to setup the ODBC.Customer_view to allow Access to
ODBC
> to that table I am getting an error about requiring exclusive access
> to the schema. The instructions I have do not say anything about
> exclusive access. But they do note "you need to give the view an
> owner name or the SQL statement will error." But they do not explain
> what this is or how to do it. I'm not sure if the schema error I am
> getting is related to this owner bit.
> > Again, this is in Vantage 6.1 and Progress 9.1d. Any further hints
> on how to get this accomplished? Especially if I have to kick
> everyone out of Vantage do I just set the number of users to 1 and
> restart the DB to achieve exclusive access?
> > Thanks,
> > Todd Caughey
> > Harvey Vogel Mfg. Co.
