Be careful with this. It would solve your problem. But other fields
such as earned hours are affected. You will need to check your
costing info and how this is hitting your wip accounts. Before you
post your wip adjust the job.
--- In vantage@yahoogroups.com, "Andrew Reed" <areed@...> wrote:
> Although I know that writing to the DB is a no-no, couldn't this be
> handled via a simple Update SQL statement?
> Obviously I'm not a vantage guru, but most DB's normalize out to a
> certain level and records are affected by a simple change like
this can
> be identified.
> Andrew
Behalf
> Of Todd Caughey
> Sent: Thursday, April 27, 2006 11:26 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] [6.1] Repair Oper with Bad Prod. Std.
> We have a job we can not close because it has a backwards
production
> standard that causes the time required to exceed the field size.
> Somehow a standard that shold be hours per 100 pcs got entered as
pcs
> per hour. In this case .128 pcs per hour. For qty 6,100 this
becomes
> over 47,000 hours. The job will not close and eventually the user
has
> to crash their Vantage session. Last time we tried just letting
it run
> as long as it needed it caused the BI file to exhaust the server's
disk
> space crashing everything and corrupting the DB.
> Sometimes we can fix one of these by deleting the oper and re-
entering
> it but there has been labor posted to this oper so that option is
out.
> I noticed a DB Conversion named "Verify/Repair Operation
Hours/Costs".
> Anyone know if this might be a solution for this job/oper? Any
other
> ideas for how to get this job closed?
> Thanks,
> Todd Caughey
> Harvey Vogel Mfg. Co.
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> YAHOO! GROUPS LINKS
> * Visit your group "vantage
> <http://groups.yahoo.com/group/vantage> " on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/> .
