Todd,
Make sure you have the port entered in the Services file in
Windows. Path: "C:\WINDOWS\system32\drivers\etc\Services"
Example: epic52 5200/tcp #Vantage
epic52sbx 5220/tcp #Vantage SandBox - Offline database
epic52trn 5210/tcp #Vantage Training database
Bill
Bill
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@...> wrote:
> Another bit of info about my earlier inquiry....
> The test.mfg routine activates the mfgsplash-gs.gif splash
screen. My "normal" Vantage.mfg brings up our customized
vnsplash.gif splash screen. Where is it set as to which splash
image gets used? I have searched for all files in the Epicor folder
containing mfgsplash-gs.gif as text and found only mfg.exe and an
install log file. If I could find out why it uses a different image
it might be an important clue.
> Also, if I run task manager while firing up the test version no
progress related processes start up. No task either. Just a splash
screen.
> Any suggestions would be much appreciated.
> -Todd C.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
Behalf Of Todd Caughey
> Sent: Tuesday, April 04, 2006 10:50 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] [6.1] Test Database - User Startup
> I setup a test database on a new USB drive I added to our Vantage
server. So far I've been able to slog through all sorts of issues
(ports, db name, etc...) and have the DB running. I copied the
Test.mfg file from the the support answerbook article and made the
necessary drive letter changes. But when I try to run it it just
displays the splash screen then goes away. If I look at a copy of
the mfgtest61.lg it shows I logged in then right out - as if the
login screen never displayed and then timed out.
> The Test.mfg file looks like:
> [mfgsys Startup]
> Executable=V:\progress\bin\prowin32.exe
> Database= H:\mfgtest61
> IniFile=M:\mfgsys61\mfgsys.ini
> ParameterFile=M:\mfgsys61\db\mfgsys.pf
> ConnectOptions=-N TCP -H vader -S 6120
> TempDirectory=C:\mfgwk61
> StartupProcedure=mainmenu.w
> OtherParameters=-rand 2 -q -basekey ini
> where V: is the drive letter for Progress
> M: is the drive letter for \Epicor to get at mfgsys61
> and H: is the new mapped drive letter pointing to the test
database location (M: = \\vader\vantagetest\)
> 6120 is the port number for the new database.
> Anyone see antything obvious in the above or know of a reason for
it not coming up with a login screen?
> Thanks,
> Todd Caughey
> Harvey Vogel Mfg. Co.
