6.10 AMM Questions - Process Flow
I don't know what happened to the beginning of my reply...
We setup the Resource Input/Output Whse to be where in the warehouse
the machine vertually is located. Then the Input & Output Bins are
shortnames for the resources. IE: Resource Name = MetalStamp 123
The Input bin would be something like MS123IN and the Output Bin
would be something like MS123OUT.
As far as setting up the bin structure for storing WIP before it
moves to the next location, we setup the generic logic of
Aisle/Row/Rack. When the WIP Product moves off the line and is not
moving to the next op's resources IN BIN, then the Inventory Control
Specialist changes the TO location when they process the item in the
material queue.
One caution to the wind is make sure that when they are ready to
continue to the press, they move the material from the correct
warehouse and bin. Even on 8.03 it defaults the wrong Whse/Bin
information...it pulls from where it thinks it should be...not where
it really was moved to.
Patty Buechler
UV Color
--- In vantage@yahoogroups.com, "bpbuechler" <pbuechler@...> wrote:
> Todd - I cannot speak to how 6.1 works. I can only speak to how
> 8.03.405 works. If the JobHead.PartNum is setup as a Part in
> Inventory, you can track the "where is it" under the Part Tracker-
> Part Location-WIP tab. However if the JobHead.PartNum is not setup
> as a Part in Inventory, then the only place you can track "where is
> it" is by the Job Tracker-Part Location-WIP tab.
> Hope this helps...
> Patty Buechler
> UV Color
> --- In vantage@yahoogroups.com, Todd Caughey <caugheyt@> wrote:
> > We are currently running a 30 day evaluation of AMM on a test
> database. Our Operations Director and our Materials Manager have
> some questions about how WIP processing is supposed to flow. We
are
> a metal stamper and parts flow through a series of operations.
> Sometimes the next stamping press is not ready so the parts are put
> away on a shelf. They are trying to determine the best way to
> organize the bin locations for WIP. Then figure out where the best
> place (or only place?) to record the location where the parts got
put.
> > If anyone has a process flow for AMM with regard to WIP that they
> would be willing to share with us (off list) I know they would
really
> appreciate it. Our demo license codes expire on the 20th so they
are
> a little under the gun.
> > Thanks,
> > Todd Caughey
> > Harvey Vogel Mfg. Co.
> > caugheyt@<mailto:caugheyt@> (for attachments)
We are currently running a 30 day evaluation of AMM on a test database. Our Operations Director and our Materials Manager have some questions about how WIP processing is supposed to flow. We are a metal stamper and parts flow through a series of operations. Sometimes the next stamping press is not ready so the parts are put away on a shelf. They are trying to determine the best way to organize the bin locations for WIP. Then figure out where the best place (or only place?) to record the location where the parts got put.
If anyone has a process flow for AMM with regard to WIP that they would be willing to share with us (off list) I know they would really appreciate it. Our demo license codes expire on the 20th so they are a little under the gun.
Todd Caughey
caugheyt@...<mailto:caugheyt@...> (for attachments)
Hope this helps...
Patty Buechler
UV Color
> Thanks,
> Todd Caughey
