I think I left a post several weeks ago asking about problems Vantage
6.10 has dealing with serial numbers during cycle counts. On Friday,
I received a reply from Vantage Support that confirmed that the cycle
count process does not prompt for serial numbers, creating problems if
there is a quantity change for serial items during the cycle count.
We actually relocated a serial numbered part during a cycle count.
All of the serial numbers were orphaned and the inventory could not be
moved because they did not have serial numbers.
If this is an issue for you, there are two Enhancement Requests that
are active: 11507MPS & 10769MPS. The first is to add the serial
number functionality and the second is to add the serial number to the
count tags (we recreated our count tags, but it is a related issue and
definitely should be part of the tag).
Also, can anyone on 8.0 confirm that this is not a problem in that
revision?
- Mike R.
revision?
- Mike R.
