[6.10 - Prgs 9.1d] File DSN - Setting Read Type
I've set up a file DSN to connect to a restricted user (only selected table grants allowed). Is there a command for the DSN file (in Program Files\common files\ODBC\DataSources) that tells it to use ReadUncommitted? When I go into Data Sources the file DSn tab does not have options for that on the user PCs.
Todd Caughey
Harvey Vogel Mfg. Co.
