6.10 - RMA Alert
Yes, you can. See the following sample code, if you're only looking for a
simple alert that the Stooges could receive. In your BAM setup, choose the
RMANum field.
Regards,
Scott Lepley
Systems Administrator
Mauell Corporation
Phone: 717-432-8686, ext. 14
Fax: 717-432-8688
Email: sal@...
Vantage version: 6.10.529
/* This email alert is sent when a new RMA is entered in Vantage */
{ud/GlbAlert.i &tablename = "RMAHead" }
FIND Customer WHERE Customer.Company = RMAHead.Company AND Customer.CustNum
= RMAHead.CustNum NO-LOCK.
IF NOT AVAILABLE Customer THEN RETURN "Cancel Send".
/* Set the To: recipient of the email */
ASSIGN Email-To = "moe@...".
/* Set the CC: recipients of the email */
ASSIGN Email-CC = "larry@...; curly@...".
/* Set the subject of the email */
ASSIGN Email-Subject = "New RMA (#" + string(RMAHead.RMANum) + ") for " +
(Customer.Name).
/* Set the email type to be HTML */
ASSIGN Email-Mime-Header = {&HTML-Mime}.
/* Set the body of the email */
ASSIGN Email-Text = "Please note that RMA #" + string(RMAHead.RMANum) + "
has just been entered in Vantage for " + (Customer.Name) + ".".
Sent: Tuesday, August 23, 2005 10:10 AM
Subject: [Vantage] 6.10 - RMA Alert
How can I, or can I, create a custom global alert on the event of creation
of an RMA using the BAM?
TIA,
Jeff
Jeff Conrad
IS Analyst
919.956.4303
Firstmark Aerospace
Durham, NC
TIA,
Jeff
Jeff Conrad
IS Analyst
919.956.4303
Firstmark Aerospace
Durham, NC
