It's in the Installation guide.
Epicor905_UpgradeGuide_905701_SQL.pdf
6.1.4 Run Schema Change
Use these steps to run the schema change.
1. Change the starting method for the AdminService for OpenEdge. To do this:
a. Select Start > Control Panel > Administrative Tools > Services.
b. Right-click on AdminService for OpenEdge and select Properties.
c. On the General tab, use the drop-down menu for Startup type to select
Automatic. Click OK. Click
Start to start the service.
2. Use the Progress Explorer Tool or OpenEdge Explorer Tool to do the
following:
a. Start the databases which you will be converting to the Epicor 9.05
level.
b. Verify that all appservers are stopped.
3. Open the Epicor Schema Change program. To do this, navigate to Start >
Programs > Epicor Software
CHANGESCHEMA. Click
Continue.
5. The Finish window appears. Click OK.
vampman_gmail
Sent: Friday, February 08, 2013 1:43 PM
Subject: [Vantage] 605 to 701 Upgrade issue
I'm doing a new install 'upgrade' of Epicor. Our data is a SQL 2008 database
using Epicor 9.05.605. I setup SQL 2012 64-bit on a new Microsoft Server
2008R2 64-bit box. I installed the 64-bit version of progress. I installed
the SQL Native Client 10 for ODBC.
I can login to the SQL Management Studio and see the data in the Epicor905
tables.
I installed OpenManage on the same box and can see that the Epicor905
database starts. I am unable to start the appservers because the data needs
to have the Schemas changed.
When I run Admin Tools (I've built a Win2008R2 64-bit server with teh
32-bit progress tools installed) it tells me that the database needs to have
When I run the Epicor Schema Change (either from the appserver or the admin
workstation) I get prompted with a password requirement. I've tried every
password we have associated with this data and install.
What am I doing wrong?
following:
level.
> Epicor 9.05 > Epicor Schema Change icon for the appropriate database.4. The Schema Change Required window appears. In the Password field, enter
CHANGESCHEMA. Click
Continue.
vampman_gmail
tables.
