Preview by Yahoo | ||
Hello,
Version: 9.50.702a
Database: SQL
We are attempting to reinstall 64bit openedge onto our appserver but can't find our main install DVDs. We looked on epicweb but was only able to find the 64bit files for the hotfixes and the service pack and the OE Mgmt Console. We couldn't find a 64bit main install file. We did find a 'rl102a.exe' on our server but it doesn't have the '-64' extension on it like the 64bit hotfixes/service pack files do. Is the 'rl102a.exe' used for both 32bit and 64bit versions? Or can someone helps us find the 64bit version of the main install file?
Thank you,
B-
On Tue, Jul 26, 2016 at 10:39 AM, detroitrdwings91@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p>Hello,</p><p><br></p><p>Version: 9.50.702a</p><p>Database: SQL</p><p><br></p><p>We are attempting to reinstall 64bit openedge onto our appserver but can't find our main install DVDs. We looked on epicweb but was only able to find the 64bit files for the hotfixes and the service pack and the OE Mgmt Console. We couldn't find a 64bit main install file. We did find a 'rl102a.exe' on our server but it doesn't have the '-64' extension on it like the 64bit hotfixes/service pack files do. Is the 'rl102a.exe' used for both 32bit and 64bit versions? Or can someone helps us find the 64bit version of the main install file?</p><p><br></p><p>Thank you,</p><p>B-</p><p><br></p><p><br></p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
Yes…I will send you an email.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Tuesday, July 26, 2016 8:52 AM
Subject: [Vantage] Re: 64bit Openedge 10.2A Help
Does anyone have any other resolutions other then calling Epicor Tech support? We no longer have support so calling epicor isn't an option for us. Any help is appreciated.
B-
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
