After a lot of digging, I finally uncovered the problem. There is
an setting in the Configurator screens that indicated whether the
configurator is "Single Level" or not. The documentation on this
seems to indicate that it is more for backward compatability.
Turning it on prevents the configurator for accessing materials and
options beyond the main level. What is not documented is that the
configurator has to be Single Level for the Set Field rules to work.
Another important point is that selecting Single Level to activate
the Set Field rules will delete any rules set for subassemblies or
phantom parts. It doesn't just ignore them, it removes them. Test
with caution.
Michael Randolph
Infinity Business Consulting
with caution.
Michael Randolph
--- In vantage@yahoogroups.com, "jslate72" <jslate@...> wrote:
> To get it to set a field in the QuoteDtl table, you have to "get
> details" while in the quote. I tried this before and that was the
> answer I received from support.
> Jeremy
> --- In vantage@yahoogroups.com, "ami_miker" <mrandolph@> wrote:
> > I am pulling my hair out over this one. I want the configurator
to
> > update the comment on the quote line. If you make a Set Field
rule
> on
> > the main assembly level of the configurator, you have the option
to
> > select the QuoteDtl.QuoteComment. For some reason, I am not
able to
> > get even a simple = "TEST" to work. The syntax checks out,
nothing
> is
> > updating. The rules at the material levels are working fine,
but
> > everything at the top seems to be ignored.
> > Any ideas?
> > Michael Randolph
