I don't think it is a session issue since I did this from 6.1 to 8.0 and
that happened throughout a span of 3 days
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Toby Boogerd
Sent: Wednesday, July 01, 2009 11:34 AM
To:
Subject: RE: [Vantage] 8.00.800 to 8.03.305
Where do I look for this session timeout?
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Chris Robisch
Sent: Wednesday, July 01, 2009 11:22 AM
To:
Subject: Re: [Vantage] 8.00.800 to 8.03.305
The Schema Change shouldn't disappear. Does your server have a session
timeout limit? If it's shorter than how long it takes to do the
conversion, I suspect that's what happened. You should remove the
timeouts for conversions... some of them can be quite long.
Also if you're on SQL, there's a file called
...clientserver\db\sql\vschmsql.dcd. You should save this BEFORE the
conversion in case you have to run the conversion again. It keeps track
of the schema changes. You should restore it from the original before
running the Schema Change again. Not sure if this applies to versions
before 8.03.405a.
----- Original Message -----
Sent: Wednesday, July 01, 2009 8:42 AM
Subject: [Vantage] 8.00.800 to 8.03.305
I am trying to upgrade my database from 8.00 to 8.03
I restored an 8.0 backup to my 803 folder and repaired and truncated,
then started the database. I then went to 8.03 menu and ran Vantage
Schema Change. It runs then later I come back to it and it has
disappeared. I then go to the Vantage 8.03 Admint Tools and it tells me
database schema changes are required:
Database Level: 8.00.800
Program Level: 8.03.305
I go back to schema change and it shows the same info in the status
field. Am I missing something?
Toby Boogerd
Information Systems
712.324.4854 | tboogerd@... <mailto:tboogerd%40rosenboom.com>
<mailto:tboogerd@... <mailto:tboogerd%40rosenboom.com>
<mailto:tboogerd%40rosenboom.com> >
