8.00.804 Rule Wizard Test Results - What help doesn't tell you
Patrick as usual you are a trailblazer, may your guiding light never fade.
I truly mean this, Thank you and good luck.
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Visit www.one.org to see how the world can be changed one person at a time.
pjw@...
Sent: Tuesday, November 22, 2005 9:47 AM
Subject: [Vantage] 8.00.804 Rule Wizard Test Results - What help doesn't
tell you.
All,
Here are my findings, please comment or note any additions or differences
you may have experienced. I'm converting all my watchdog report builder
reports to rule wizard entries first if possible, next a dashboard, finally
a crystal report.
I'm doing simple test on the ability of the Rule Wizard.
I'm testing with the FOB table and three fields FOB, Description, Terms and
I added CheckBox01, Date01 and Numeric01.
Some of the items were reported on incident 1519441 - Epicor tech support
doesn't want to here more than one or two problems per incident.
1) Can't delete individual rules once added.
You can only delete the entire customization from the load screen "Select
Customization and Translation". Best work around is to export good
customizations often so you can revert back if needed.
2) Add more than 6 rules get a limit error.
3) Finding conditions for CONTAINS, STARTSWITH and EQUALS with are case
sensitive which makes them useless on text fields.
This limits the command ability. I think I would prefer rules
not being case sensitive.
4) Setting Date Ranges you can't read "First Day of Month" type selections
because the drop down box is not wide enough.
We need customization ability on the customization screens so we can
fix them too. (:-)
5) Settings Results:
Bold - Doesn't Work
Disable - Works (this will disable the field noted changing the background
to grey) OK - changes field box to green background Warning - changes field
box to yellow background Error - changes field box to red background
Highlight - changes field box to blue background
Invisible - (I didn't test this one)
Mandatory - Doesn't Work
6) I'm really missing a couple of examples of .net code examples to expand
on the ability here:
A) pop up message box for a mandatory field not filled out
B) pop up message for numeric range or data range which is not
logical.
B) also a complex one like order line price not equal to zero
unless a misc change is present.
Summary you change colors for numeric fields such as in the help example.
There looks like a lot of potential her but many dead ends need to be fixed
first. Again, Here are my findings, please comment or note any additions or
differences you may have experienced.
Patrick Winter
Specialty Screw Corporation
Live Network: Vantage 6.10.514, Progress 9.1D08, Windows 2003 Server,
Crystal 8.5.3.975
Test Network: Version: Vantage 8.00.804, OpenEdge 10.0B02, Windows 2003
Server, Epicor Crystal 10.0.0.533, Runtime XI
Yahoo! Groups Links
All,
I'm converting all my watchdog report builder reports to rule wizard entries
first if possible, next a dashboard, finally a crystal report.
Best work around is to export good customizations often so you can revert
back if needed.
fix them too. (:-)
Bold - Doesn't Work
to grey)
Warning - changes field box to yellow background
logical.
first.
Patrick Winter
Crystal 8.5.3.975
