8.00.808G - Cannot run canned Crystal Forms
In Version 8, the install programs have bad habit of not getting the
system agent setting entered or once entered they might point to the
wrong directories or even the wrong database. In eportal is a
solution for troubehooting printing, it goes all through the system
agent settings.
--- In vantage@yahoogroups.com, "Joe Luster" <jluster@...> wrote:
> We had Ben Nixon come in and install 8.0 and everything on SQL. (So I
> know it was installed right!) We are now training in 8.0 and can't run a
> canned Crystal Form. (Sales Order print preview). How does Crystal
> connect to Vantage now in SQL? I was told to go to the System Agent and
> check ports. Everything looks right but it looks way different than 6.1
> Progress.
> <http://www.coldjet.com>
> Joe Luster
> Network Administrator
> Cold Jet, LLC
> 455 Wards Corner Road
> Loveland, Ohio 45140
> 513-831-3211 ext. 308
> 513-831-1209 FAX
> Celebrating 20 Years of Dry Ice Technology and Innovation
Progress.
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
did he have you load crystal runtime xi r2 on all the pcs?
Tom Morrison
Sent: Fri 8/4/2006 9:40 AM
Subject: [Vantage] 8.00.808G - Cannot run canned Crystal Forms
Progress.
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
Oh yes, forgot to say that. It is installed.
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
_____
Of Tom Morrison
Sent: Friday, August 04, 2006 10:07 AM
Subject: RE: [Vantage] 8.00.808G - Cannot run canned Crystal Forms
Tom Morrison
<mailto:jluster%40coldjet.com> ]
Progress.
<http://www.coldjet.com <http://www.coldjet.com> >
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
when you open your system agent, under ODBC connection, do you have the progress user id and password populated?
Also in the Status section where it says "connection id"... is this field populated? Is there an active connection?
Is the system agent attached to a schedule to startup?
Tom
Sent: Fri 8/4/2006 10:25 AM
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
_____
Of Tom Morrison
Tom Morrison
Progress.
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
I just download a PDF from Epicor that showed me what to do. The server
file and client directory settings were wrong.
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
_____
Of Tom Morrison
Sent: Friday, August 04, 2006 11:47 AM
Tom
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
_____
Behalf
Of Tom Morrison
Tom Morrison
Progress.
<http://www.coldjet.com <http://www.coldjet.com> <
http://www.coldjet.com <http://www.coldjet.com> > >
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
