Gary,
That's very valuable info. Thanks so much for sharing.
FYI: I also found out this morning from Epicor that there is a known
bug regarding the pack slip data definition and trying to link the
orderdtl table!
John
orderdtl table!
John
--- In vantage@yahoogroups.com, "Gary Parfrey" <garyp@...> wrote:
> John
> Sometimes you cannot retrieve data into the XML if the
relationships are
> two or more deep in the definition
> Also, it does not allow you to enter the same table in twice,
therefore
> for example you cannot get a sales managers name as it is linked
from
> and stored within the salesrep table.
> Gary
Behalf
> Of jahatcher43
> Sent: 11 February 2008 14:02
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: 8.03.305H BAQ Report Designer
> Hi Gary,
> Thanks for your response. I guess the million dollar question
> is, "What are the certain cases?" I'm not looking to do anything
> unusual and the table actually already appears in the default data
> definition. Do you or anyone know where this is documented when you
> cross that line?
> I had checked with Epicor in the past on the SDK and it is a $10k
> package with a mandatory $10k in training. Needless to say, I find
> it entirely unacceptable that I would need to spend $20k to add a
> table to a report.
> Any further insights would be *greatly* appreciated.
> Thanks,
> John
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Gary Parfrey" <garyp@> wrote:
> > John
> > Up until Vantage 803, you needed the SDK to add any tables into
the
> > report definitions (Vantage 8.00).
> > Since Vantage 803 you can add tables, but in certain cases you
may
> need
> > the SDK in order to keep away from ODBC and SQL.
> > Gary Parfrey
> > Dot Net IT Limited, Reg No 4412519
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ] On
> Behalf
> > Of jahatcher43
> > Sent: 10 February 2008 23:37
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Two of the post on this thread caught my attention because I have
> > been told both that the SDK is required to add tables and get the
> > data in Crystal and that this is not true.
> > I am having the issue of not getting any data for the OrdDtl
table
> > when I link it into the pack list document. (link via
> > company,ordernum, orderline, orderrelnum to the Packdtl table).
The
> > XML document is produced with no data provided for the OrdDtl
table.
> > Has anyone else had this experience and more importantly been
able
> to
> > resolve it? I have tried reducing the links to just the company
> code
> > in case it considered the linking I selected to be inappropriate.
> > Anyone?
> > Thanks,
> > John
> > > Check to see whether the running of the BAQ report generated
any
> XML
> > > If it did set the datasource in the crystal report and see if
you
> > can
> > > pick up and verify the data
> > > Then save it and redeploy and rerun the BAQ report
> > > See if it then works
> > > Gary
> > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%
> > Behalf
> > > Of vantage
> > > Sent: 08 February 2008 20:06
> > > Subject: RE: [Vantage] 8.03.305H BAQ Report Designer
> > > Melissa,
> > > Can't say this is the same problem, but I had same problem in
> > version
> > > 305I.
> > > When I created the same report in version 403D the report ran
> fine.
> > > Technical support told me that there were lots of bugs fixed in
> > version
> > > 400.
> > > Steve
> > > -----Original Message-----
> > > From: melissa hietala [mailto:kevmel822@
> > > <mailto:kevmel822%40yahoo.com> ]
> > > Sent: February 08, 2008 1:35 PM
> > > Subject: [Vantage] 8.03.305H BAQ Report Designer
> > > I'm looking at creating reports with the BAQ Report Designer.
> After
> > > reading
> > > through some how-to instructions, I started by creating a
simple
> BAQ
> > > with
> > > just one table as a test, which is then used in the BAQ report
> > designer.
> > > In
> > > the BAQ report designer, I'm attempting to run the report by
> > clicking
> > > the
> > > "Test Report Form" under Actions on the main menu. The report
> does
> > run,
> > > however the report isnt populated with any data from the BAQ.
The
> > report
> > > is
> > > basically blank.
> > > Any info on the BAQ Report Designer or any suggestions/help
would
> be
> > > much
> > > appreciated!
> > > Thanks in advance,
> > > Melissa Hietala
> > > UMC, Inc.
> > > melissah@ultramc. <mailto:melissah%40ultramc.com> com
> > > __________________________________________________________
> > > Be a better friend, newshound, and
> > > know-it-all with Yahoo! Mobile. Try it now. http://mobile.
> > > <http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ>
