8.03.400 and 8.03 on Same Server?
Edward,
Another option to consider that does not require port and/or directory
manipulation or result in performance degradation associated with OS
virtualization is to virtualize the applications themselves. Altiris makes
an application they call the "Software Virtualization Solution" that
effectively isolates applications, including registry settings, drivers,
etc., into compartments they call slices. You can activate, deactivate and
roll back slices as you wish without affecting the base OS or other
applications. The net result is that you can install multiple versions of
the same application without creating port conflicts or overwriting
directories and as a side benefit it is free:
http://www.download.com/3120-20_4.html?qt=altiris
<http://www.download.com/3120-20_4.html?qt=altiris&tag=srch&tg=dl-20>
&tag=srch&tg=dl-20
The only caveat is that you cannot run the two virtualized applications at
the same time.
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
<http://www.aspacia.com/> http://www.aspacia.com/
Edward F. Fox, Jr.
Sent: Thursday, March 27, 2008 5:06 AM
Subject: RE: [Vantage] 8.03.400 and 8.03 on Same Server?
Thank you Mark and Jason.
I was planning to go down the route of Jason's option A and probably will,
but I hate changing default directories because I have had that cause issues
in the past (not with Vantage.)
I'll consider VMware and see how that works. I have never worked with it
before but I have known about it for years.
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone 401-596-0162 Fax 401-596-1050
www.maxsonautomatic.com <http://www.maxsonautomatic.com/>
_____
Behalf Of
Jason Claggett
Sent: Wednesday, March 26, 2008 7:51 PM
Edward,
Yes, Vista 8.03.400 WILL overwrite your mfgsys803 folder. There is a way
to do this properly and there is an Epicor technical document explaining
what you have to do.
A couple of things to consider:
1. OpenEdge 10.0 & 10.1 use the same ports for PET
2. 305 and 4xx use the same AppServer port numbers 83xx, etc.
3. 305 and 4xx use the same directory structure
Work Around A:
1. Get the Epicor document describing how to make OE10.0 OE10.1
co-exist on the same server
2. Change the AppServer ports to 84xx
3. Install the 4xx in a directory called mfgsys803400
Work Around B:
1. Install on Virtual server as Mark has suggested. Not sure of
any problems...but I am a fan of virtual servers (MS, VmWare, etc.)
Either method you choose you will need to install a new client on each
machine and that includes the .NET 3.0 Framework, WSE 3.0 and Crystal
Reports .NET 3.0 Runtime. Be sure to install the 4xx client into a
different directory on the workstation.
Hopefully this information is helpful.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@2wtech. <mailto:jason%402wtech.com> com
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Edward F. Fox, Jr.
Sent: Wednesday, March 26, 2008 4:49 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] 8.03.400 and 8.03 on Same Server?
I just started to research the upgrade to 8.03.400. We have 8.03 running
on
our new server with a test copy of our database and I was going to jump
right up to 8.03.400. After reading the install guide, it appears that
8.03.400 is going to write over the 8.03 directory. I like to install
all
the software and have it running and then just migrate the database
through
all the steps.
Has anyone installed these versions on the same server? What did you do
so
they would co-habitate?
Controller
<http://www.maxsonautomatic.com/> tomatic.com/>
I just started to research the upgrade to 8.03.400. We have 8.03 running on
8.03.400 is going to write over the 8.03 directory. I like to install all
the software and have it running and then just migrate the database through
all the steps.
Has anyone installed these versions on the same server? What did you do so
Controller
Phone 401-596-0162 a Fax 401-596-1050
I used VMWare Server[1] (which is free) to do this. If I screwed up, I could
restore the VM folder and get a mulligan...
Mark W.
1. http://www.vmware.com/products/server/
P.S. Don't set your RAM more than 1GB. It goes REALLY slow. Why? I have no
idea...
Edward,
Work Around A:
Work Around B:
Jason Claggett
MCP #3856159
312.533.4033 x8039
jason@...
on
all
through
all the steps.
so
Controller
Yes....that's exactly how we have our DEVelopment server setup. Epicor
tech support helped me configure it...and, we use a different port for
ProgressExplorer for the .40x environment......we even had SQL2000 and
SQL2005 on the same box for a while, & that worked OK as well.
Gary
--- In vantage@yahoogroups.com, "Jason Claggett" <jason@...> wrote:
> Edward,
> Work Around A:
> Work Around B:
> Jason Claggett
> MCP #3856159
> 312.533.4033 x8039
> jason@...
> on
> all
> through
> all the steps.
> so
> Thanks
> Controller
Another vote for VMware Server here, why potentialy screw up a
production environment when virtualisation is available ?.
If you do use VMware to setup a test environment, and show it to
users, just make sure that they are aware that the performance will
not match that of the productino server/setup.
you do so
up, I could
> Mark W.
have no
> idea...
Controller
_____
Jason Claggett
Edward,
Work Around A:
Work Around B:
Jason Claggett
MCP #3856159
312.533.4033 x8039
Behalf
on
all
through
all the steps.
so
Controller
Edward,
&tag=srch&tg=dl-20
the same time.
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Edward F. Fox, Jr.
Controller
_____
Behalf Of
Jason Claggett
Edward,
Work Around A:
Work Around B:
Jason Claggett
MCP #3856159
312.533.4033 x8039
Behalf
on
all
through
all the steps.
so
Controller
VMWare is fantastic, providing a good DR path if you have external
storage. I would very much like to implement it to replace 3 very old
servers, but unless you can separate your storage from the server
machine itself (via SAN or iSCSI to a NAS), you don't get the DR
benefits. As I don't have the budget for adding any external storage, I
elected not to implement VMWare in a production capacity.
Once you start using it, you'll see how easy it really can be. The
"free" version does a great job of handling multiple virtual-machines
hosted in any one physical server. The retail products work together
with your hardware and storage allowing you to seamlessly move a machine
from one physical host to another when, for example, you purchase a
newer/beefier physical host.
Great stuff. Wish I had the $.
--Ari
Sent: Thursday, March 27, 2008 7:06 AM
will,
issues
Controller
<http://www.maxsonautomatic.com/> >
<http://geo.yahoo.com/serv?s=97359714/grpId=20369/grpspId=1705007183/msg
Id=63591/stime=1207055355/nc1=4507179/nc2=3848642/nc3=5286672>
