8.03.403 - Time phase with multiple plants
Dear Ken:
This worked perfectly!
We are very happy with the results.
Thank you very much.
Lynn Khalife
--- In vantage@yahoogroups.com, "Ken Williams" <ken@...> wrote:
> Here's my quick & dirty fix, I'm sure there's a better way but for
> testing purposes this seems to work quite well.
> I created a button next to the plant field called "Change Plant". I
> then created an Event Wizard based on clicking this button. I also
had
> to add a load event, which I'm sure could be handled otherwise.
Here's
> the code to go with it:
> First you have to add the Private WithEvents to the beginning of the
> code:
> '// ** Wizard Insert Location - Do Not
Remove 'Begin/End
> Wizard Added Module Level Variables' Comments! **
> '// Begin Wizard Added Module Level Variables **
> '// End Wizard Added Module Level Variables **
> Private WithEvents cmbPlant As EpiCombo
> '// Add Custom Module Level Variables Here **
> Then the code for the on load:
> Private Sub TimePhasForm_Load(ByVal sender As
object,
> ByVal args As EventArgs) Handles TimePhasForm.Load
> '// Add Event Handler Code
> cmbPlant =
> ctype(csm.GetNativeControlReference("f7641147-3182-4540-bb0a-
8ab960aad5c
> 2"),EpiCombo)
> End Sub
> Then the code for my button:
> Private Sub btnPlant_Click(ByVal Sender As Object,
ByVal
> Args As System.EventArgs) Handles btnPlant.Click
> '// ** Place Event Handling Code
Here **
> cmbPlant.ReadOnly="false"
> End Sub
> The end result is a button you can push to open up combo box.
> On a side note, I thought this would be a great process for a BPM.
I
> tried toggling the only two fields that are called by the process.
> Neither one seems to be affected by either a pre or post process
BPM.
> Kind of strange, I've done a dozen or so BPM's and figured this
would
> work well, but unless I'm missing something basic (like the enable
> button, which I have done in the past), it's ignoring my BPM.
> Ken
Behalf
> Of Ken Williams
> Sent: Tuesday, November 18, 2008 12:55 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: 8.03.403 - Time phase with multiple
plants
> I'm curious if anyone else has comments on this. I just spent a few
> minutes looking at the process vs. the menu item and I can't see a
way
> to enable the field either.
> Perhaps there's a way to override through some programming? A set
> field.enable or whatever the syntax might be....
> Ken
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ] On
> Behalf
> Of Lynn
> Sent: Tuesday, November 18, 2008 10:48 AM
> Subject: [Vantage] Re: 8.03.403 - Time phase with multiple plants
> Thanks Ken.
> I wouldn't dream that TabStop would change anything. However the
> Enabled property is already set to TRUE. TabStop is the only
> property that is True for Time Phase Inquiry; but set to False in
the
> sub-process screen. All other Properties for the cmbPlant control
> are identical.
> You are correct; I deployed the customization and it did nothing.
> I don't know what else to try.
> But thanks for the Deployment Instructions for the Customization.
At
> least now I understand how to deploy customizations for a sub-
process!
> Lynn
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com> , "Ken
> Williams" <ken@> wrote:
> > This is a sub-process customization. So, the first thing we have
> to do
> > is find which sub-process is being called when you right click a
> part
> > and go to time phase.
> > 1. Context Menu Maintenance (under System Mgmt, Utilities)
> > 2. Search for Part.PartNum Context
> > 3. Select Time Phase on the left, note the Process ID
> (IMGO3400 on
> > mine)
> > Now we can change the sub-process.
> > 1. Sub-Process Maintenance (under System Mgmt, Utilities)
> > 2. Search for Time Phased Inquiry
> > 3. Grab the matching Process ID (IMGO3400)
> > 4. Select Customization from the drop down
> > 5. Hit Save
> > It's been a while since I've done this, you may have to restart
> Vantage
> > for it to work.
> > On a side note, Tab Stop isn't what you're looking for. Tab Stop
is
> > when you hit the tab button and it goes to a specific field.
You're
> > looking for Enabled I believe.
> > Ken
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of Lynn
> > Sent: Tuesday, November 18, 2008 9:51 AM
> > Hi Ken:
> > As you suggested, I am trying a customization of the screen to
open
> > that field up.
> > The only difference in the cmbPlant properties between going into
> > Time Phase Inquiry directly (Job Mgmt, Gen Ops) and going into it
> > from a right click on the Part Number in Job Entry is the TabStop
> > property.
> > Although I have little confidence in this acheiving my objective,
I
> > forced the TabStop to equal True on a customization via JobEntry,
> > right-click on Part; however, I cannot figure out how to deploy
the
> > saved customization in order to test it.
> > Since it is not a regular menu item, I cannot deploy it in Menu
> > Maintenance.
> > Any ideas?
> > Lynn
> <mailto:vantage%
> > > If you go into Time Phased Inquiry directly (say from Job Mgmt,
> > General
> > > Ops), you can change your plant.
> > > I haven't had the need yet to go fix this problem, I assume
> > > customization on the screen to open that field up would be all
> you
> > would
> > > need to do.
> <mailto:vantage%
> > Behalf
> > > Of c.chest
> > > Sent: Thursday, October 30, 2008 7:33 AM
> > > Subject: [Vantage] 8.03.403 - Time phase with multiple plants
> > > If I have a part that is manufactured in plant A and is a
> transfer
> > part
> > > in plant B, if I am logged into plant A looking at time phase
on
> > that
> > > part, shouldn't I be able to change the plant and see the time
> > phase
> > > information from plant B's perspective? There is a drop down
box,
> > but
> > > it doesn't bring up any other plant except the one I am logged
> > into.
> > > Does anyone know what I might be missing?
> > > Cindy
If I have a part that is manufactured in plant A and is a transfer part
in plant B, if I am logged into plant A looking at time phase on that
part, shouldn't I be able to change the plant and see the time phase
information from plant B's perspective? There is a drop down box, but
it doesn't bring up any other plant except the one I am logged into.
Cindy
If you go into Time Phased Inquiry directly (say from Job Mgmt, General
customization on the screen to open that field up would be all you would
need to do.
Of c.chest
Cindy
Hi Ken:
As you suggested, I am trying a customization of the screen to open
that field up.
property.
Although I have little confidence in this acheiving my objective, I
right-click on Part; however, I cannot figure out how to deploy the
Maintenance.
Any ideas?
Lynn
General
would
> need to do.
Behalf
> Of c.chest
part
that
phase
but
into.
> Cindy
This is a sub-process customization. So, the first thing we have to do
is find which sub-process is being called when you right click a part
3. Select Time Phase on the left, note the Process ID (IMGO3400 on
mine)
5. Hit Save
It's been a while since I've done this, you may have to restart Vantage
for it to work.
On a side note, Tab Stop isn't what you're looking for. Tab Stop is
when you hit the tab button and it goes to a specific field. You're
Ken
Of Lynn
Hi Ken:
that field up.
property.
Maintenance.
Any ideas?
Lynn
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Ken
General
would
> need to do.
Behalf
> Of c.chest
part
that
phase
but
into.
> Cindy
Thanks Ken.
property that is True for Time Phase Inquiry; but set to False in the
are identical.
But thanks for the Deployment Instructions for the Customization. At
least now I understand how to deploy customizations for a sub-process!
Lynn
to do
part
(IMGO3400 on
> mine)
> 5. Hit Save
Vantage
> for it to work.
> Ken
Behalf
> Of Lynn
> Hi Ken:
> that field up.
> property.
> Maintenance.
> Any ideas?
> Lynn
> General
you
> would
> > need to do.
> Behalf
> > Of c.chest
transfer
> part
> that
> phase
> but
> into.
> > Cindy
minutes looking at the process vs. the menu item and I can't see a way
Ken
Of Lynn
Thanks Ken.
are identical.
Lynn
to do
part
(IMGO3400 on
> mine)
> 5. Hit Save
Vantage
> for it to work.
> Ken
Behalf
> Of Lynn
> Hi Ken:
> that field up.
> property.
> Maintenance.
> Any ideas?
> Lynn
<mailto:vantage%
> General
you
> would
> > need to do.
<mailto:vantage%
> Behalf
> > Of c.chest
transfer
> part
> that
> phase
> but
> into.
> > Cindy
then created an Event Wizard based on clicking this button. I also had
to add a load event, which I'm sure could be handled otherwise. Here's
code:
'// ** Wizard Insert Location - Do Not Remove 'Begin/End
Private Sub TimePhasForm_Load(ByVal sender As object,
cmbPlant =
ctype(csm.GetNativeControlReference("f7641147-3182-4540-bb0a-8ab960aad5c
2"),EpiCombo)
End Sub
Private Sub btnPlant_Click(ByVal Sender As Object, ByVal
'// ** Place Event Handling Code Here **
End Sub
On a side note, I thought this would be a great process for a BPM. I
Neither one seems to be affected by either a pre or post process BPM.
Kind of strange, I've done a dozen or so BPM's and figured this would
Ken
Of Ken Williams
Subject: RE: [Vantage] Re: 8.03.403 - Time phase with multiple plants
Ken
Behalf
Of Lynn
Thanks Ken.
are identical.
Lynn
to do
part
(IMGO3400 on
> mine)
> 5. Hit Save
Vantage
> for it to work.
> Ken
Behalf
> Of Lynn
> Hi Ken:
> that field up.
> property.
> Maintenance.
> Any ideas?
> Lynn
<mailto:vantage%
> General
you
> would
> > need to do.
<mailto:vantage%
> Behalf
> > Of c.chest
transfer
> part
> that
> phase
> but
> into.
> > Cindy
