8.03.404 or higher users
Hi Paul,
> Our biggest complaints are the speed of 8.03 (we are running in a citrix
> environment), and the number of screens (clicks) that need to be
> accessed to get where they need to go, vs. 6.1 which may have only been
> a couple of clicks to get the same info.
We didn't come from 6.1 but if you described what commands consume the most
vacuum, er, time then maybe others can chime in with some short-cuts.
Mark W.
P.S. O.T. A bunch of Wonsils are going to be in your neighborhood in June:
http://www.mrcride.com
There are several areas that are causing our users troubles in the
conversion from 6.1 to 8.03.404, I was wondering how many other
companies are actually running 8.03.404 regardless of patch level. It
would be great to hear some feedback from others of how their users have
migrated from 6.1 to 8.03 and what issues they have had and how they
were resolved.
I would appreciate any feedback I can get.
Thanks!
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 1114
Fax: 262-252-4974
Email: paul.pachniak@...
WWW: http://www.aceprecision.com
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
Paul,
Same complaint with the number of clicks and our users.
Chris
were resolved.
Thanks!
Paul E. Pachniak
Accounting Manager
Fax: 262-252-4974
