The JMtlSts epiview used in Material Status check only includes (linked - purchase direct) PONum and DueDate.
You could probably set up a Foreign Key View to POHead table and then indicate the Vendor Name on the Detail sheet. However, it would not be visible in the 'canned' list view.
If you need it in the list view, create a dashboard from a BAQ and bring it into the app as a new form tab.
Rob Brown
Dan Shallbetter <dans@...> wrote:
I would like to add the vendor name to the Job material Status list view
found in the Job tracker. Is it possible to add additional fields to the
grid list without using SDK? Or would I create a new sheet with a BAQ
report?
Dan Shallbetter
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Rob Brown
report?
Dan Shallbetter
Do You Yahoo!?
