8.03.405 - G/L Problem
We are having the exact same issue. Can you tell me the exact steps you performed that fixed your problem? Thanks!
Mike..
--- In vantage@yahoogroups.com, "Epi Cor" wrote:
Problem resolved with reboot.
Through running the COS/WIP Recon in Test, we see that it will also repair the report issues, but have not run in live due to open activity.
THANKS TO ALL FOR THE HELP!
--- In vantage@yahoogroups.com, "Cathy" wrote:
When you run the Inventory/WIP Recon report - does it have a N or Y in the
posted column?
If it is N you need to run the Capture COS/WIP Reconciliation process in Job
Management?
wl_bl
Sent: Wednesday, December 05, 2012 1:59 PM
Subject: [Vantage] 8.03.405 - G/L Problem
Our accounting department has reported the following problem:
Shipments are invoiced and the invoices have posted; however, the
transaction did not clear the A/R Clearing account nor did the values
post to the COS account. When looking at the Inventory/WIP Recon
Report, all values still show in the A/R clearing. The G/L also does
not display any Periodic Posting Activity. Problem has existed for three
days.
I have been unable to determine a cause or a fix. Has anyone else
experienced this and if so, what did you do to fix it?
Thanks in advance.
wl
days.
Thanks in advance.
wl
posted column?
Management?
wl_bl
days.
Thanks in advance.
wl
> posted column?
> Management?
> wl_bl
> days.
> Thanks in advance.
> wl
