They all are set up as "READ UNCOMMITED".
Blake Clemens
DMC
Of Ned
Sent: Tuesday, June 09, 2009 10:30 AM
Subject: Re: [Vantage] 8.03.405A Reports/Queries/Printing Slowness
That could be a problem, how are the ODBC settings setup on the local
machine? They need to be all setup to be "READ UNCOMMITTED"
If not, it is possible that a record lock can occur, which can lead to
that
problem.
Blake Clemens
DMC
Of Ned
that
problem.
----- Original Message -----
<mailto:blake.clemens%40d-m-c.com> >
To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
Sent: Tuesday, June 09, 2009 10:22 AM
Subject: RE: [Vantage] 8.03.405A Reports/Queries/Printing Slowness
> Yes
> Thanks,
> Blake Clemens
> DMC
Behalf
> Of Bartosz Niemczewski
> Sent: Tuesday, June 09, 2009 10:19 AM
> Do you have any reports using odbc connection ?
> From: Blake Clemens <blake.clemens@...
> Sent: Tuesday, June 9, 2009 9:10:43 AM
> We're Progress. I've tried just stopping the Process and TaskAgent
> appservers but that didn't help.
> Thanks,
> Blake Clemens
> DMC
> ____________ _________ _________ __
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
> Behalf
> Of Ned
> Sent: Tuesday, June 09, 2009 10:09 AM
> To: vantage@yahoogroups .com
> Subject: Re: [Vantage] 8.03.405A Reports/Queries/ Printing Slowness
> Are you an SQL customer? I would quesiton whether you are having
record
> locks or not which can cause a backup similar to what you describe.
> If it is only printing, then that can be re-started by stopping and
> starting
> the processappserver and taskappserver, you shouldn't need to kill the
> main
> appserver to restart that.
> From: "Blake Clemens" <blake.clemens@ d-m-c.com
> <mailto:blake. clemens%40d- m-c.com> >
> To: <vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> >
> Sent: Tuesday, June 09, 2009 10:00 AM
> Subject: [Vantage] 8.03.405A Reports/Queries/ Printing Slowness
>> I'm starting to have an issue with our Vantage system. We are running
>> 405A. For no apparent reason our printing seems to stop working...
our
>> queries seem to "hang"... and any reports we try to run will also
>> "hang". I'm kind of at a loss as to why this will suddenly happen. My
>> only resolution is to kick everyone out of Vantage and shut
> down/restart
>> the system. Does anyone have any ideas as to what could be causing
>> this? I asked the obvious users if they were running any "big"
reports
>> or trying to create any queries that could be a load on the system.
> The
>> answer was no. Any direction here would be greatly appreciated. I'm
>> thinking that it might be time for me to perform another "Dump and
>> Load". Yipppeeee!!! !!!!
>> Thanks,
>> Blake Clemens
>> IT Systems Engineer
>> Delmarva Millwork Corporation
>> (800) 360-2364 x132
>> ***Privileged & Confidential* **
>> This email, together with any attachments, is intended for the named
>> recipient(s) only and may contain privileged and confidential
>> information. If received in error, please inform the sender as
quickly
>> as possible and delete this email and any copies. If not an intended
>> recipient of this email, you must not copy, distribute or rely on it,
>> and any form of disclosure, modification, distribution and/or
>> publication of this email is prohibited.
>> Unless stated otherwise, this email represents only the views of the
>> sender and not the views of Delmarva Millwork Corporation.
>> [Non-text portions of this message have been removed]
>> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
>> have already linked your email address to a yahoo id to enable
access.
>> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
>> Crystal Reports and other 'goodies', please goto:
>> http://groups. yahoo.com/ group/vantage/ files/.
> <http://groups. yahoo.com/ group/vantage/ files/>
>> (2) To search through old msg's goto:
>> http://groups. yahoo.com/ group/vantage/ messages
> <http://groups. yahoo.com/ group/vantage/ messages>
>> (3) To view links to Vendors that provide Vantage services goto:
>> http://groups. yahoo.com/ group/vantage/ linksYahoo
> <http://groups. yahoo.com/ group/vantage/ linksYahoo> ! Groups Links
> have already linked your email address to a yahoo id to enable access.
and
> http://groups.yahoo.com/group/vantage/linksYahoo
<http://groups.yahoo.com/group/vantage/linksYahoo> ! Groups Links
