8.03.4XX Search Box Question
Thank you all for your help with this issue. Your feedback has been very helpful! Adding "<DefaultSearchPageSize value="1000" />" to the default.mfgsys file allows you to edit the search criteria.
Â
Thanks again!
Dustin Biniek
UMC, Inc.
DustinB@...
--- On Wed, 12/3/08, Thomas, Lynn A. <thomasl@...> wrote:
Subject: [Vantage] Re: 8.03.4XX Search Box Question
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Date: Wednesday, December 3, 2008, 8:44 AM
Brian,
If it's not in your .mfgsys file, it won't show up in the configuration editor. I discovered that a little while ago - and only because I've somehow wound up with at least two client installations on my machine. Copying the new default.mfgsys to the shortcut target [i.e. the client I actually use] produced the results Nigel and Bernie [who wrote me offline] described.
Now, how to get it in the file if you don't have an up to date version to copy, I'm not certain. Wait a minute, I am too. Cut and paste this line right below the "DefaultSearchFormL ocation" line in your default.mfgsys:
<DefaultSearchPageS ize value="1000" />
And then you can change the number to whatever you wish. Don't know about other changes in the file, though.
Lynn Thomas
Senior Engineer
SAIC
317-357-4041 X255
I would like to set a default for the number of rows that is returned when a user is using a search box. For instance, if a user currently attempts to search for a job in job entry, and then clicks the "Options" button under the job search, a box will popup with a checkbox for "Return All Rows" and a textbox for "Maximum Rows Returned." By default the "Maximum Rows Returned" is equal to 100. Is there a way that I can modify this so that the maximum rows will default in as another number?
Â
Dustin Biniek
UMC, Inc.
DustinB@...
Check out configeditor.exe in the client803 folder - on the user tab
is an option to set the nuber of items returned by search
Returned." By default the "Maximum Rows Returned" is equal to 100.Â
> Â
> Thanks,
> Dustin Biniek
> UMC, Inc.
> DustinB@...
I just tried that and if it's there, the label is the most obscure
thing I've found yet in Vantage. MAXBOMRU on the application tab has a
value of 100, but when I changed that to 1000 and logged on, the
search box still defaulted to 100 rows. I'm on 405A. Do you know
what I should look for??
Lynn Thomas
Â
> > Dustin Biniek
> > UMC, Inc.
> > DustinB@
Hi Lynn,
The setting is on the User tab of ConfigEditor and it's labeled
"DefaultSearchPageSize"
Nigel.
has a
> Lynn Thomas
tab
user
> Â
> Thanks,
> > > Dustin Biniek
> > > UMC, Inc.
> > > DustinB@
I don't see this setting in 8.03.405. Is this new in .406? I
remember Rich Riley mentioning this in Vegas but don't remember what
version its tied to.
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@... ~ 734-864-5618 ~
www.advancedphotonix.com
Of Nigel Kerley
Sent: Wednesday, December 03, 2008 9:23 AM
Hi Lynn,
<http://geo.yahoo.com/serv?s=97359714/grpId=20369/grpspId=1705007181/msg
Id=71532/stime=1228314167/nc1=3848642/nc2=3848581/nc3=5191954>
Brian,
Now, how to get it in the file if you don't have an up to date version to copy, I'm not certain. Wait a minute, I am too. Cut and paste this line right below the "DefaultSearchFormLocation" line in your default.mfgsys:
Lynn Thomas
Senior Engineer
SAIC
317-357-4041 X255
Thanks Lynn. That's obnoxious behavior in my mind - the config tool
should give you the entire repertoire of config options and write the
XML appropriately.
(Nice to meet you in Las Vegas, by the way!)
-bws
Picometrix
Of Thomas, Lynn A.
Sent: Wednesday, December 03, 2008 9:44 AM
Brian,
offline] described.
default.mfgsys:
Id=71538/stime=1228315444/nc1=3848640/nc2=5541753/nc3=5170420>
