8.03 Dashboard clear/refresh
that doesn't work so well, because everyone can set their own hotkeys.
And also, for some reason, my hotkeys reset after a while. There has
got to be a way to refresh and clear the page. Can we not access that
same methods that those toolbar buttons call?
--- In vantage@yahoogroups.com, "Michael McWilliams"
<mmcwilliams22@...> wrote:
> I have had a couple instances when I needed to use some toolbar items.
> It may not be the best method but it seems to work for me
> What I have done is used hotkeys and then on button click use
> sendkeys.send I know in the dashboard you can assign hotkeys to
> the clear, refresh, and refresh all.
> --- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@>
> wrote:
> > Is there a way to add a clear and refresh button on the dashboard. I
> > assume you would have to put it on the tracker view of the dashboard.
> > I couldn't use the normal "otrans.clear()" or "otrans.refresh()"
> like
> > on other customized screens. I just want a way for someone to
> easlily
> > enter in information to get filtered on the tracker and have a
> > "search" button instead of always having to go up to the toolbar and
> > decided which of the two refresh buttons to hit.
I couldn't use the normal "otrans.clear()" or "otrans.refresh()" like
on other customized screens. I just want a way for someone to easlily
--- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@...>
like
easlily
